True GDM-72 Refrigerator Logo
Posted on May 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do I have to use a TRUE thermostat on my T-72?
My current thermostat will hold my average temp at 35.53 and I need the temp to stay around 40. Is there an aftermarket thermostat I can use that will give me a tighter temp window? I need the fridge to stay between 36 and 46.
  • Joe Palazola Mar 30, 2014
    I would not recommend replacing the thermostat with an air sensing thermostat. The factory thermostat senses the coil temperature and cycles the unit off when the coil reaches approx. 15 degrees and back on at approx 40 degrees. I have used air sensing thermostats in the past and at erratic times the unit will ice up the coil. The absolute best thing I have done is to remove the factory thermostat and install a Emerson digital ETC110000, put the sensor in the coil and set it for 15 degrees with a 25 degree differential and play with the settings if necessary. Go no lower than 13 degrees with a 27 degree differential. Wiring and installing the ETC will require a decent tech and is not a DIY unless you are very handy.
mike cooper
Level 3:
  • Master 884 Answers
  • Posted on May 18, 2012
mike cooper
Master
Level 3:
Answers
884
Questions
Helped
404869
Points
1991
The True thermostat sits on the evaporator in a piece of tube attached to the coil. If it won't switch off at your required temp even at position 1 you can use an air temperature type thermostat in it's place. It will sit in the same place but the sensing end will coil up behind the fan. Get a bar fridge thermostat and it'll adjust to your needs.
5 Related Answers
Anonymous
  • 619 Answers
  • Posted on Jan 18, 2008
SOURCE: KBFA20ERSS- Fridge stopped staying cool; thermostat doesn't work
Hi, if you can find the input of cool air there a slider to shut it make little way to in cool air to keep cool down.
If there a possible thermostat make it lesser so that thew thermostat will on and off.
Anonymous
  • 87 Answers
  • Posted on Sep 15, 2007
SOURCE: refrigeration problem
It sounds very much like control board problem. The chances of both sensors at fault seems unlikely. Unusual that it is the exact same temp unless they are your setpoint requirements. I would advice contacting reliable fridge guy to check the cabinet. Hope this is of some if not much help.
Anonymous
  • 828 Answers
  • Posted on Jun 03, 2008
SOURCE: sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Anonymous
  • Posted on Mar 01, 2009
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
roadrunning1
Paul G
  • 161 Answers
  • Posted on May 10, 2009
SOURCE: FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Temperature gauge does not give accurate reading
check to see if fan stays on all the time
if not i have seen thermostats put in backwards
the thermostat is what holds water to the block to warm
to op temp then open to cool
Temp.on inside is to cold
Sheila you will need two things and that is your model Number and the Serial Number then click here=> Ask Our True Service Technician I know because I asked without having the Serial Number but once I called or e-mailed back they were very helpful! True takes pride in their customers respect. If helpful please rate if not then ask me whatever you need to solve. my guess is the thermostat is defective or out of calibration. Thank You, Sea Breeze
Twice now, our thermostat, being set on 72, we wake up in the am and it was set on 40!!! The house temp was 60, but it was freezing in the morning..i reset the temp back to 72, and it works again. Just...
Ok this is a state that is running on a program. You are going to have to go through and set the set points on it. This can be done by looking at the screen and pressing the program button. Set the tempature at the right time. There will be settings for monday through friday and sat/ sunday. There may be as many as 4 different set points for each of these so take you time and go through each one.
TRUE Salad Unit freezing food/compressor will not cycle properly
Double check to see that you do have in fact, the correct thermostat. I have found a chart that shows that the differential is all over the board. There is a way to adjust these thermostats but is very time consuming and if you are not a refrigeration tech, you may struggle with the procedure.
https://www.truemfg.com/Support/Resource-Library
What is the correct temp at dryer exhaust when dryer is on ''high'' I have a electric bill that has doubled and I am researching each appliance in my home.
The high thermostat usually cycles around 145°F (on average), but it is the time it takes to dry a load that really matters. Nothing should take more than an hour. Usually around 40 minutes average.
Both inside and outside units start and run for about 10 minutes then both turn off for 30-40 mins or so. therm is set for 72. it is averaging 77 right now. it just does not run long enough to cool off the...
check the thermostat accuracy try to set at65 and check the run time and the temperatureif it runs more than usual and the temperature decrease means that the thermostat is defective
Top True Refrigerators Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a True Refrigerator Expert? Answer questions, earn points and help others
