Font size
I'm aware of two approaches to try to workaround the lack of a font size setting under the menu settings.
1) If you you have updated your device to (or if it already came with) Froyo (Android 2.2) or you flashed one of the Gingerbread (Android 2.3) leaked ROMs, go to 'Menu > Settings > Accessibility', and tick both 'Accessibility' (this one you can leave ticked for good) and 'Zoom mode' (for this one you'll get a confirmation popup screen). A magnifying square will appear. Untick this setting to remove it. Whilst active, you can move it around by tapping, holding and dragging any of the 4 stripes on its edges. You can also set the magnification level, by tapping on either '-' or '+' signs. If you don't want to keep activating and deactivating it whenever you need it, you can leave it partially hidden, by dragging it to one of the screen's corners, the one which would bother you less.
2) Install 'Any Cut', by Jeff Hamilton, from the Android Market. Then, tap and hold any empty area on any of your home screens, and select 'Shortcuts > Any Cut > Activity'. Wait for the list to be updated, scroll down, tap 'Display' (attention: NOT 'Display settings') anf 'OK'. Tap that newly created shortcut. Tap the arrow below 'Font' and select 'Large', and 'OK'. Unfortunately, this trick doesn't seem to work on the latest 4.5.3-66 Gingerbread build.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further.
Regards,
Carlos
