SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
SOURCE: water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
SOURCE: Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
SOURCE: leaking water
turn the water off its behind the unit on the wall .
you might have a busted pip in the door but only tech' can fix that ....
