Started looking at the boards inside the DL5.2i found that the horn micro switch and the on and off micro switch were the same I don't need a horn so I just swapped them out.Started looking at the boards inside the DL5.2i found that the horn micro switch and the on and off micro switch were the same I don't need a horn so I just swapped them out.
You can't post conmments that contain an email address.
Your dynamic mics should be fine, phantom power provides one positive 48 volt potential to one side of the coil, and a negative 48 volt potential to the other side of the coil so your mics will effectively see 0 volts as these potentials will cancel each other out ( hence the name "phantom" power). so provided that your microphones are wired properly internally, and your xlr leads are in good condition you will not damage any of your equipment.
i think its an micro controlling unit problem for solve this problem please make air conditioner,s main supply switch turn off and after two minutes again turn on for reset of micro controller system . i hope after that it will work .
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. Check for the following when dl occurs: Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Hi, "dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. Check for the following when dl occurs:
That is the solenoid clicking. dl is a door lock error, and you can test and replace the door lock switch, but I am doubtful that will correct the problem. I really hope it does, but I have seen the dl code with the solenoid clicking at the rear of the(Whirlpool Duet) washer before and it was a faulty control board. I hope I am wrong, but... You can try unplugging and resetting the washer. In the case I saw, the machine would reset, but gradually got to a point that it had to be reset numerous times. (too many). Anyway, I hope I am wrong and best wishes. (Don't forget to test the door lock switch. Use a multimeter and check for continuity. A lack of continuity indicates a faulty switch. Hope this helped.
Check your controller program using PP1programmable for PG drive controller ( VSI,VR2,and Pilot+) or using Dynamic wizard for Dynamic Controller (DX,DL,Commando,SHARK, and RHINO)
