If you are experiencing an AC problem with your DieHard 1150, which is a portable power source, there could be a few potential issues to consider:
Check the power source: Ensure that the DieHard 1150 is properly charged. Connect it to a power outlet using the provided AC charger and let it charge for the recommended duration as mentioned in the user manual.
Inspect the AC outlets: Check the AC outlets on the DieHard 1150 for any visible damage or loose connections. Ensure that the devices you are trying to power are compatible with the power requirements of the DieHard 1150.
Reset the unit: If the AC outlets are not functioning properly, try resetting the DieHard 1150. Disconnect all devices and turn off the unit. Press and hold the power button or the reset button (if available) for a few seconds. Then, turn the unit back on and test the AC outlets.
Contact DieHard customer support: If the above steps do not resolve the AC problem, it is recommended to contact DieHard's customer support for further assistance. Provide them with the specific details of the issue and any troubleshooting steps you have already taken. They will be able to provide you with more specific guidance or arrange for repairs if necessary.
There must be a switch for the compressor. The images aren't sharp enough to see. Yes, it has a 'Select' button for the compressor. It also has a set pressure auto-off, so make sure that is set to zero. Here is the manual.
I got this free Pdf manual from reliable-store. com for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
If you have a 12volt standard electrical system in your vehicle.
It is both positive and negative. The travel inverter converts this 12 volt DC current into 110v 60hz AC current so you can plug in your electronics that require standard household current to charge/operate.
There is a built in USB port if you device will accept this for 12 volt power. It also has the power oultet with ground for 110v 6hz power.
Link below has a good picture and description. Hope this helps!
Sears Diehard or Interstate would make a battery for your vehicle. Look for something with over 600 cca and you should be ok for the winter.
Diehard makes a Platinum battery, but it costs over $189.99.
Diehard Gold batteries are like $109 or so.
Walmart sells batteries that are comparable to the Diehard Gold for under $100.
However, I just bought a Platinum battery for my 1997 Cadillac Deville Limo and it seems to work alright so far and has a 4 year free replacement warranty.
In general, the more you pay, the better the battery up to the 'best' which is the Diehard Platinum.
Walmart and Interstate do not offer a battery that has as long of a warranty or as good of a design as the Platinum from Diehard which uses proprietary technology to get a better warranty than normal.
The Platinum name in the PT Cruiser has nothing to do with the Platinum name for Diehard, by the way.
Good luck on finding a suitable replacement battery for your 2004 PT Cruiser Platinum.
