20 Most Recent Diehard Gold Portable Power 950 with Jump-Starter - DC & USB Power Questions & Answers
diesel generator det website: www.dieselgeneratortech.com
Diehard Gold... | Answered on Nov 29, 2019
I had a Wal-Mart version that did the same thing. Turned out to be a bad battery after all. You should be able to replace the battery.
Diehard Gold... | Answered on May 03, 2014
I don't know of any 'push rose', on an internal combustion engine. Ah, you mean 'push rods' perhaps, the things that open the valves? The push rod is just a steel rod that works on a cam and presses the rocker, which presses the valve stem tip. Hopefully they just need adjusting, if not, it is a catastrophic failure!
https://www.lifanpowerusa.com/product-category/generators/energy-storm-series/
Electrical... | Answered on Jul 12, 2020
top of your electrical panel
Electrical... | Answered on Jul 10, 2020
output depends on what loads you draw on any genset
Electrical... | Answered on Jun 30, 2020
power to starter have never seen one to know if they have a solenoid for it or not
Electrical... | Answered on Jun 29, 2020
you have carb passages that are still clogged up. when you do get it all clean and running always use a little seafoam in your fuel. it works very well on small engined units... a few ozs in 5 gallons is plenty and stores very well also.
Electrical... | Answered on Jun 12, 2020
check the operation of the oil level sensor . No oil no start
Electrical... | Answered on Jun 08, 2020
From what I see on other disposals, the hex is in the middle of the bottom. Remove the paper tag.
https://www.youtube.com/watch?v=J0OByRuoYM0
Electrical... | Answered on Jun 06, 2020
You could always use "Belt Ease" from an Auto Parts store. It's made for squeeky belts.
-Lonnie
Electrical... | Answered on Jun 03, 2020
The generator does not operate in accordance with the specified technical conditions, such as too high stator voltage, iron loss increases; if the load current is too large, the copper loss of the stator winding increases; if the frequency is too low, the cooling fan speed becomes slow, affecting the heat dissipation of generator; the power factor is too low, so that the rotor excitation current increases, resulting in the rotor heating. Check whether the indication of monitoring instrument is normal. If it is abnormal, necessary adjustment and treatment must be carried out to operate the generator in accordance with the specified technical conditions.
Electrical... | Answered on May 29, 2020
Diehard Gold Portable Power 950 with Jump-Starter - DC & USB Power Logo
8 questions posted
Top Diehard Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Diehard Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Diehard Electrical Supplies
Most Popular Question
work light portable power 1150 will not
  • Electrical Supplies
