Question about Diehard Gold Portable Power 950 with Jump-Starter - DC & USB Power
Work light on Diehard Portable Power 1150 will not turn off. Continues to flash.
Posted by Norman Robinson on
sherlywang
    Master:
  • 425 Answers
Diesel generator det website: www.dieselgeneratortech.com
Posted on Nov 29, 2019
1 Related Answer
jcrowder0846
John A. Crowder
  • 470 Answers
SOURCE: dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
Posted on May 11, 2012
What could be the problem?
I had a Wal-Mart version that did the same thing. Turned out to be a bad battery after all. You should be able to replace the battery.
May 03, 2014 | Diehard Gold Portable Power 950 with...
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
May 11, 2012 | Dell Inspiron 1150 Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Wont Start Up
try taking out the memory.you can have the instructions by going to this link---http://support.dell.com/support/edocs/systems/ins1150/sm/upgrades.htm#1105389.Incase that does not work than i would suggest to get the motherboard replaced.You can contact the tech support incase you have the warranties and get it replaced
Dec 22, 2007 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Diehard Gold Portable Power 950 with Jump-Starter - DC & USB Power Logo
230 people viewed this question
Top Diehard Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Diehard Electrical Supply Expert? Answer questions, earn points and help others
