What you have to determine is why the system is not booting. Is it a software or a hardware issue? Try booting your laptop, and as soon as the machine starts to bootup, press the key or keys required to enter the setup (CMOS/BIOS). Check to see if the hard drive is being recognized by the CMOS. If so, check to boot devices and te boot order to be sure that the hard drive is selected as the firs boot device. If the drive is being seen and is the first device and it still won't boot, the problem is most likely a corrupted software load. Without a boot disk you are pretty much up the creek without a paddle for basic repair. If your machine has a recovery partition, you may be able to access it and restore the laptop to factory load, but all your programs and data will be lost if you do this. If the BIOS/CMOS did NOT recognize your hard drive, you can attempt to remove and reinstall it and try again. It that fails then the only solution is a new hard drive.
SOURCE: computer loads operating syatem not found
Check HDD power and IDE cable carefully. Better replace them. Open BIOS. Do you see your HDD on BIOS ? Do you hear any sound from your HDD ? Do your HDD produce some heat ? If no, replace your HDD with new one. If yes you need to repair your BOOT file and MBR. Do you have any XP installation CD ? If not collect now. If yes, boot from CD. follow instruction and press 'R' to enter recovery console. Give password , leave blank if none. Select os by pressing 1 (in single boot). Now in command prompt type this two command one by one "fixboot" and "fixmbr" without quote. Type y to if required. Than type exit to exit recovery console.
If this does not solve the problem, you must give a fresh OS install. Keep informing.
SOURCE: Hi when try to boot my
Hi mohamed04, I recommend you to perform an HDD self test so we can understand if you have a faulty HDD or just a Software problem caused by any windows update or virus that might have corrupted your windows boot file. For performing an HDD self test you should turn on the unit and when HP invent logo appears press " ESC " key, then you will have access to other menu where you should select option " F2 - System Diagnostics" and then " F4 - Hard disk Test" . After process finishes it will provide you a message with " success" or #xx Fail". You need a new hard drive and install fresh windows operating system. Maybe after that you can try to put your old hard drive to external enclosure hard drive and try to recover your computer will recognize the hard drive. Hope this helps, HRH
SOURCE: Whenever I start my HP
That message means that your hard drive is bad and is not seen by your computer. If it is under warranty, HP will fix it. If not, you can find a hard drive for it for $70 +, depending on what capacity you purchase. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
Although the hard drive is bad, a good tech can retreive your data, ie: documents, pictures and music from it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Boot device not found Please instal l an operating
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
SOURCE: when I start the laptop (HP HDX 16) I get this
The Windows edition listed in BIOS (Vista) is referring to the operating system that came with the computer. BIOS's System Diagnostics will always say the OS is Vista, because that is the original OS that HP put on the system. BIOS itself, however, cannot detect an operating system on the new Hard Drive because there is no operating system. In order to get an operating system, you have a couple options:
Depending on the terms and length of your warranty, you may be able to get HP to reinstall the operating system back onto the new Hard Drive. The amount you would pay depends on the warranty. Many warranties, however, become void when you change physical components in the computer (especially with laptops). If this is the case, you will have to try the next option.
You can buy a retail copy of Windows either online or from an electronics store. The price will depend on what edition you purchase, but it will probably cost you at least $100 US.
You can install a Linux operating system on your Hard Drive. If you've never heard of Linux, it is an operating system based on much of the same code as Mac operating systems, but has a more "Windows-like" feel to it. Linux operating systems are NOT the same as windows, and some programs that work in Windows will not work in Linux; you would need to find the Linux counterpart for these programs. One of the best things about Linux operating systems are that they are absolutely free to download, install and use. A very popular and stable Linux operating system is Ubuntu, which can be found at: http://www.ubuntu.com/
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
hope this helps
hope this helps
