Computers & Internet Logo
A
Anonymous Posted on Mar 17, 2015
How do I enlarge the screen so it fills the page?
My page used to fill the screen and now is about 2/3 the size. How do I restore a full page?
robert
Level 3:
  • Apple Master 2,548 Answers
  • Posted on Mar 17, 2015
robert
Apple Master
Level 3:
Answers
2548
Questions
0
Helped
870605
Points
8043
Put ur cursors on the edges of the screen and then manual move edges using touchpad click and cursor movement.
How to enlarge the screen to full size
right at the top in the right hand corner there are set of tabs
one is a line , the other is 2 squares off set and the last is a red section with a white X
the line reduces the page to the task bar so that you can look at other pages , the off squares brings the page from 1/2 size to full screen and the red one closes off the page
My down load picture are so small, how do i enlarge them, so i can post them
Ok, you see when you download images from google or other service; don't download from the results page! in google; click the image, then click 'view image'; image opens in new window; right click on it and save the full image.
down-load-picture-small-enlarge-post-3x24vpx20nhydej15kwplfm4-5-2.png In Bing; just click the image; the full preview fills up the screen, save.
HOT TIP: to get better resolution images:
1. Google: click search tools; under size: select large
down-load-picture-small-enlarge-post-3x24vpx20nhydej15kwplfm4-5-5.png 2. Bing: click Image size, select large.
down-load-picture-small-enlarge-post-3x24vpx20nhydej15kwplfm4-5-9.png Good luck! Vote if you found this helpful
1helpful
3answers
How do you reduce the screen size.
  • Launch the Web browsericon1.png on your Mac system. Unless you have changed the home page, the Apple site greets you.
  • 2 Click the green "+" symbol in the upper left corner of the window. This enlarges the window so it takes up the entire screen. If you want to return the window to the former size, click the green "+" again.
  • Read more : http://www.ehow.com/how_5959434_change-screen-size-home-mac.html
    When I bring my computer up there is a black space on the left side. I want the screen to enlarge so I can not see this. How do I do that?
    There should be a menu option on the monitor it self. press the menu option and configure the size and position option to adjust the screen display. That should resolve your complication.
    Not full screen
    Hi Marie-Ann, which page are you referring to? Is it the Desktop? If so, right-click on it and choose Screen resolution. Try changing that and it may solve your problem.
    I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
    I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
    two ways to solve it.
    1. Adjust the resolution to the optimal setting so it fills the entire screen.
    2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
    To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
    If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
    Full screen but writing very small. programs only fill center of paperhow do i enlarge the writing part
    RMB click on the desktop back ground, Click on Screen settings and choose a size (Sliding bar) which is best for you. I'd start at 1024 X 768.
    I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
    Press Copy until Reduce/Enlarge appears in the top line of the dis
    The following options are available in the Reduce/Enlarge menu.
    you will have three choices.
    Reduce/Enlarge
    Actual Size
    Custom 100%
    Full Page 91%
    Legal > Ltr 72%
    Also:
    Use Photo Fit to Page when you want to automatically enlarge your original
    photo to fill the printable area of the paper size loaded in the paper tray.
    Photo Fit to Page only enlarges original photos that are standard photo sizes. The
    standard photo sizes are as follows:
    • 3.5 by 5 inches (9 by 13 cm)
    • 4 by 6 inches (10 by 15 cm)
    • 5 by 7 inches (13 by 18 cm)
    • 6 by 8 inches (15 by 20 cm)
    • 8 by 10 inches (25 by 25 cm)
    For originals containing text or photos that are not a standard size, use Reduce/
    Enlarge.
    Manual is HERE Copy functions start on page 27.
    1helpful
    How do you enlarge on the HP309A SERIES
    1. Use the following guidelines to determine which setting to choose:
      • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
      • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
      • Copying a photo to full-size paper : Choose Fill Entire Page .
      • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
    2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
    3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
    4. Select Size and press OK to access the copy size options.
    5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
    6. Press Start Copy Color or Start Copy Black .
    Top Apple Computers & Internet Experts
    Paul Carew
    Grand Canyon Tech
    Grand Canyon Tech
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
