Why does my indesit widl126,the easy iron button is stuck on but it washes fine but the dryer is not drying it just gets very hot .
The washing side of the machine is fine but when i used the drying side of the machine the other day it was on for about 3 hours and the washing just got very hot but did not dry please help
It sounds like the seal is worn out around the hose possibly or it is just loose and needs tightening. Depending on how old your machine is, the hoses get dried and cracked over time as do the seals.
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit.
Refer to your users' manual re. where the filter is....
