20 Most Recent
Indesit Wa155 Wd10 Wd11 Wd12 Washing Machine Door Handle Kit Questions & Answers
Indesit index XWA91683 will not start Wash Mode?
If your Indesit XWA91683 washing machine fills with water but does not start the wash cycle, and you have confirmed that the pump is working fine, there could be a few potential causes for the issue, including a malfunctioning motherboard. Here are a few steps you can take to troubleshoot the problem:
- Power Cycle: Start by turning off the washing machine and unplugging it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This can help reset the machine's internal settings and may resolve temporary issues.
- Check Door Interlock: Ensure that the washing machine's door is securely closed and the door interlock mechanism is functioning properly. A faulty door interlock can prevent the machine from starting the wash cycle. Check for any loose connections, damage, or obstructions in the door interlock mechanism.
- Reset the Control Panel: Depending on the model, your washing machine may have a combination of buttons or a specific sequence to reset the control panel. Consult the user manual for your Indesit XWA91683 or contact Indesit customer support for instructions on how to reset the control panel to factory settings.
- Examine the Control Board: If the above steps do not resolve the issue, there could be a problem with the motherboard or control board of the washing machine. Inspect the control board for any visible signs of damage, such as burnt components, loose connections, or corrosion. If you notice any significant issues, it may be necessary to replace the control board. Consult a professional technician or contact Indesit customer support for further assistance.
It's worth noting that diagnosing and repairing issues with the motherboard or control board typically require professional expertise. If you are not confident in handling these repairs yourself, it is recommended to consult a qualified technician or contact Indesit customer support for assistance. They will have the knowledge and tools to accurately diagnose the problem and provide appropriate solutions.
How do I remove the back access cover on an Indesit WIE 167 washing machine to replace belt
Follow these procedures to remove the back access cover on an Indesit WIE 167 washing machine and replace the belt:
Disconnect the washer from the electrical outlet and turn off the water supply.
Move the washing machine away from the wall so that the back can be accessed.
Find the screws that secure the rear access cover. Often, they are positioned throughout the cover's perimeter.
Remove the screws using a screwdriver and store them in a secure location.
Carefully remove the washing machine's back access cover. Using a flat instrument, such as a putty knife or a scraper, to pull the cover away from the machine may be useful.
Once the cover is removed, the belt should be accessible. Remove the old belt from the machine with care.
Put the replacement belt on both the motor and drum pulleys.
Align the back access panel with the washing machine and secure the screws to reattach it.
Reconnect the washing machine and activate the water supply.
Verify that the replacement belt works properly by putting the washing machine through a series of tests.
When servicing a washing machine, it is essential to observe all safety precautions. If you are uncertain or uncomfortable with any of these processes, it may be better to call a skilled technician or service center for assistance.
Washing machine indesit iwc5085 drum blocked
If the drum of your Indesit IWC5085 washing machine is jammed, there are a number of methods you can try to take to address the problem:
Look for tiny objects: Look for tiny objects that could be lodged in the drum, such as coins or buttons.
They may result in the drum becoming blocked and impair its ability to spin.
Inspect the filter: Look inside the washing machine's bottom-mounted filter for any particles or anything that might be the obstruction.
Remove the kick plate from the washing machine's bottom to gain access to the filter.
Inspect the pump: Look for any obstructions or blockages in the washing machine's bottom-mounted pump. Remove the kick plate from the washing machine's bottom to gain access to the pump. If there is a clog, remove it with care before attempting to restart the washing machine. If the drum isn't spinning at all, check the belt. It could be loose or broken. Unplug the washing machine and take off the back panel to inspect the belt. Check the belt for any indications of wear or damage. The belt must be replaced if it is damaged or loose.
It could be required to seek the aid of a qualified repair technician if none of these measures succeed in fixing the problem.
Indesit PWDC8125 UK washing machine
it seems like the issue is not resolved even after replacing the pump. It could be related to a problem with the control board or a faulty water level sensor. You may want to consult a professional repair service
Indesit integrated dishwasher Model DIE2B19UK when I try to start a new cycle, press play, close the door it beeps and when I open the door all lights are flashing
When you attempt to start a new cycle on your Indesit integrated dishwasher (model DIE2B19UK), the dishwasher beeps, and the lights begin to flash.
Various factors could be to blame for this problem.
A few troubleshooting tips are provided below:
Examine the door:
The dishwasher door should be securely closed and latched.
The dishwasher will only start if the door is properly shut.
Verify the water inlet:
Verify that the water inlet is turned on and that the inlet hose is free of glaring obstructions or kinks.
Check the filters: Check the filters in the dishwasher for any blockages or debris. Clean or replace the filters as necessary.
Check the pressure switch: The pressure switch is responsible for sensing the water level in the dishwasher. It could be malfunctioning, which is causing the dishwasher not to start.
Check the control board: The control board controls the dishwasher's functions. It could malfunction, causing the dishwasher not to start or displaying the error code.
Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer for further assistance. They can provide more detailed troubleshooting steps or recommend a service professional to diagnose the problem.
