SOURCE: need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
SOURCE: hunter fan remote 85095-02, red signal light glowing continualy
It's continually transmitting. My guess is there is a button stuck causing the unit to run down batteries. If no button stuck, you'll probably have to replace the remote -- it's a fulty transistor.
Charlie
SOURCE: Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
