There is no defrost timer in your side x side model. The defrost cycle is controlled by a computer mother board on the outside back wall of the cabinet located under a metal cover plate approx 8x 10 inches. That board controls almost every function of the refrigerator including the defrost cycle.
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
SOURCE: GE side by side
I have a G E side by side refrigerator model #GSS201ephww and need a part for it . i can't find this model anywhere on the internet now . even on the web site given in the owners manual.. please help..
serial # is MG268486
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
SOURCE: where is the defrost timer located on ge side bty
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
SOURCE: GE Eterna Series side x side refridgerator
Temperature adjust displays not showing, can not adjust temp, is something disconnected?
