Question about GE Refrigerators
Location of Defrost Timer
Where is the Defrost Timer located on my GE refrigerator model #GSS25LGMABB
Posted by bsrt on
  • bsrt Apr 01, 2009
    there is no board on the back of the unit
Anonymous
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
  • Anonymous Apr 02, 2009
    right hand corner plate cover it
Model gss25jetabb. Where can I find the defrost timer?
The defrost timer is built into the control board and is likely not the problem with a defrost problem. Item location 801 in this photo is the control board=> HERE The most likely problem on your model is the=> Defrost Thermostat WR50X10068 and the=> WR51X10059 Defrost Heater location 240 and 230 in the photo=> HERE Appliance 911
Jan 03, 2016 | GE Refrigerators
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
Ge defrost timmer location gss
DEfrost timer is placed beside compression unit, behind refrigerator.
Jul 04, 2013 | Refrigerators
Compressor and fan stop working
There is a possibility that the defrost timer turned the compressor and fans off and stuck in the defrost lobe of the defrost timer. I want you to try turning the defrost timer slowly clockwise. The defrost timer is in location 257 behind the control panel inside the fresh food compartment. Here is a photo of the parts location HERE
If doing this causes the refrigerator to work again then replace the=> WR9X489 Defrost Timer
If this does not work I want you to try something else so let me know what happens Thanks
Sea Breeze
Apr 05, 2013 | GE Profile Performance 25.2 cu. ft....
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
Fridge stopped cooling but freezer works what could it be
Most likely the=> WR09X10041 Defrost Timer
found inside the fresh food section and behind the control panel. Click HERE for the location. Part location number 648 is the defrost timer. Location number 618 is the=> WR51X10038 Defrost Heater Assembly
If you change the defrost heater then you should also change the WR50X10071 Defrost Thermostat
and that is the location number 620 found HERE First I want you to try turning the defrost timer slowly clockwise until compressor and fans stop. Leave like this up to about 30 minutes. You should hear crackling and sizzle noise inside the freezer. If after 30 minutes the compressor and fans do not restart this will indicate the defrost timer and that part will need replaced. Try that first and let me know what happens. I will be here to answer questions if you like, Thanks Sea Breeze
Aug 15, 2012 | GE Refrigerators
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Feb 16, 2012 | GE Refrigerators
Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
May 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Aug 25, 2008 | Refrigerators
Refrigerators Logo
957 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
