I have a Zanussi Electrolux Jetsystem 1400 7KG When I select cycle etc and then it starts to fill with water it stops. Some water comes in the machine but not sufficient to was also it stops operating. I cant afford a new one just now can you say what the problem is and if I can get the parts it requires replaced.
J Watson
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
You usually turn off your inlet valve after your washing is done. Well, if it keeps filling after u hv turned off, you have a problem with your inlet valve, which you should replace.
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.
