Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door...
If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
