20 Most Recent Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator Questions & Answers
Door to refrigerator will not close properly.
The refrigerator door seal is being broken when you open the freezer door? Sounds like the rubber magnetic strip needs to be replaced on the refrig. door, they wear out after a number of years.
10/30/2017 7:55:29 PM • Kenmore 73262 /... • Answered on Oct 30, 2017
I'm looking for the cubic
That's a 22.1 cubic feet fridge/freezer. 22.1
6/9/2011 5:19:04 PM • Kenmore 73262 /... • Answered on Jun 09, 2011
I just bought a new Kenmore fridge and everytime
THE UNIT HAS TO HAVE A GOOD TILT TO THE BACK,, THIS HELPS THE AIR BEING PUSHED THROUGH THE FREEZER WHEN THE DOOR IS CLOSED, AND IT HELPS WHEN THE UNIT GOES INTO DEFROST, IT HELPS DRAIN THE WATER ,, ALL NEW TOP MOUNT REFRIGERATORS THAT I HAVE CAME ACROSS DOES THIS IF IT IS NOT TILTED BACK
1/19/2011 2:47:04 AM • Kenmore 73262 /... • Answered on Jan 19, 2011
Water build up in the freezer
When your refrigerator defrost the condensation has no place to exit to because of a restriction in the drain and that could be water that has turned into ice or possiably a food partical or foreign object. Defrost it compleatly by leaving freezer door open for aprox. an hour at least make sure ref is level front to back an d you should not have this problem anymore. Please rate me and let me know if this helped. Thanks
8/25/2010 4:03:15 AM • Kenmore 73262 /... • Answered on Aug 25, 2010
Kenmore 10672206200
Sounds like the relay and or overload on the comprsor have are bad.
Pull refrigerator out and check to see if the compresor is running either by listening or feeling. If compresor is not running the part on the side of it that is attatched is bad and you will need to replace. If I helped you in resolving your problem please rate my assistance.Thanks !
8/25/2010 3:54:20 AM • Kenmore 73262 /... • Answered on Aug 25, 2010
My Kenmore 105.70204990 top freezer refrigerator
Can you describe the noises? If it is a compressor, you cannot change it yourself and it would probably cost close to $250 to do the job anyways.
1/5/2010 6:41:12 AM • Kenmore 73262 /... • Answered on Jan 05, 2010
Kenmore frig is 9 yrs old and was leaking water in
drain ic clogged and what motor?
12/18/2009 1:47:39 AM • Kenmore 73262 /... • Answered on Dec 18, 2009
2answers
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
5/3/2009 9:49:10 PM • Kenmore 73262 /... • Answered on May 03, 2009
Need to remove the big piece of sheet metal on whirpool refridg
the rear panel is not removable. you need to clean the drain from inside the freezer compartment.
  • 1 remove food from freezer
  • 2 remove shelving and icemaker if equipped
  • 3 remover rear access cover in freezer usually 2 or 3 screw
  • 4 clean ice out from underneath the coil you will uncover the drain hole
  • 5 force hot water thru drain hole i use a turkey baster or large syringe
  • 6 reassemble in reverse order.
if you have any further questions please ask here and I'll be glad to assist any way I can. thanks Peyton
3/5/2009 10:48:29 PM • Kenmore 73262 /... • Answered on Mar 05, 2009
Remove the sheet metal panel from Whirlpool refridge
3/5/2009 10:47:12 PM • Kenmore 73262 /... • Answered on Mar 05, 2009
6answers
Refrig and freezer does not work
you need a new ac condenser
1/19/2009 2:09:15 PM • Kenmore 73262 /... • Answered on Jan 19, 2009
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
12/18/2008 6:59:41 PM • Kenmore 73262 /... • Answered on Dec 18, 2008
2answers
Outside freezer is hot to the touch
Its normal, the heat is coming from the condenser which is integrated within the freezer cabinet and is completely out of sight.
7/30/2008 9:36:21 PM • Kenmore 73262 /... • Answered on Jul 30, 2008
Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator Logo
32 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
39 m looking cubic
  • Refrigerators
