oh me MINE did that exact same thing UNIT IN SAFEGUARD.. grrrrrrrrrrr.. YEP NEW CAMERA TIME.. sometimes they tell you that those battery cahrgers will work but it all really just defects them
solution 1:
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
solution 2:
Turn off the camcorder.
Remove the battery or disconnect the AC power adapter for 60 seconds.
Insert the battery or reconnect the AC adapter.
Turn on the camcorder.
If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service
additional info that might help:
According to the manual, the error code C:31:xx:xx means an error that
>the owner can fix by himself has occured and that by taking out the
>cassette and replacing it or by disconnecting the battery pack and
>fixing it back should solve the problem.
Error "23" means: "S reel emergency during normal rotation",
i.e. the problem is with the tape deck mechanism and specifically
the supply reel.
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
hi i have the sony DCR-PC53E camcorder with the error code E:61:10 does anyone have any suggestions on how to fix this problem any help will be more than appreciated
I get the exact same message.
My camcorder keeps showing this message. Sometimes it works flawlessly but most of the time, this error shows up. What gives?
