Once it is already OPEN there is probably something side the safe and on the back side of lock access that will allow you to change the combination. I do not know the model number but this is standard practice so that one must know the current combination to reset it to a new one. Specifically how would be in your manual. The key would allow the over ride to access this recombination. I have a digital door lock that works similarly and you can either enter the numbers or use a key to unlock it unlike a analog safe it has both a master code (which allow the ability to create new codes or delete old codes) and an access code.
