Question about Sentry Fireproof Safe
I WANT TO CHANGE COMBINATION ON MY SENTRY FIREPROOF SAFE HOW?
I WANT TO CHANGE COMBINATION OF MY SENTRY SAFE
360-2HR
CLASS AK-385-294
HOW DO I DO IT
THE SAFE HAS A KEY AND ELECTRONIC KEY PAD
Posted by CATHERINE KRAUS on
Lisbeth Barrera
    New Friend:
I have a sentry safe csw 4747 Idont no tha combination
how do I do the safe a key and electronic key pad
Posted on Oct 08, 2011
  • Lisbeth Barrera Oct 08, 2011
Anonymous
    Problem Solver:
  • 6 Answers
You can go to senturysafe.com and download the user manual for your safe. it will tell you how to change the code.
Posted on Sep 12, 2010
How to change combination of model 1250 sentry fire safe
dear sir i was given a sentury safe#1250 ,serial #g969560 the safe is open how do i figure out the combination?
Feb 08, 2013 | Sentry Fireproof Safe
I have a sentry safe r4132 can the combination be change Thank you
I have a sentry safe R4132 can the combination be change .,SN. AN165498
Jul 03, 2008 | Sentry Fireproof Safe
How do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
Jun 06, 2010 | Sentry Fireproof Safe
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jan 29, 2010 | Sentry Fireproof Safe
I have a sentry safe with a key and combination lock i have misplaced my combination now what
Sentry Safe lost combination. First, find your sentry floor safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Jul 13, 2009 | Sentry Fireproof Safe
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Nov 16, 2008 | Sentry Fireproof Safe
SENTRY SAFE
Locksmiths agree the factory code is burnt into memory and can not be erased. When you buy a sentry safe you have to set a user code to give out as that code can be changed. program instructions
CAN NOT OPEN MY SAFE, MISPLACED INFO, LOCKED CODE NUMBER IN SAFE. ELECTRONIC FIRE SAFE NUMBERS ON OUTSIDE OF SAFE OA3817 BA69609
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
May 01, 2008 | Sentry Fireproof Safe
I lost the cobination for the safe and i cant open it
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements.
Apr 01, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,383 people viewed this question
Top Sentry Home Security Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
john h
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
