The check wiring message suggests a short probably in a speaker wire. Check that the terminal leads for the speakers are properly covered in insulating tape. Check the rest of your wiring, if you can, to check for any section where the insulation is worn and could come into contact with anything. Next remove the faceplate and use a pen to press and hold the reset button. The button is near the bottom of the middle of the receiver.
If the error persists, then another section of the wiring is making metal on metal contact with the car or another wire. You should contact a JVC dealer or the company that provided the kit with the KD-R45.
I hope this helps.
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
i am engneer i hav also check all wiring it is internly problem it is pcb fault (check wiring then reset) in jvc usb car cd
