Question about JVC Car Audio & Video
How to reset jvc kd-r330 - JVC Car Audio & Video
Posted by John M Glenn on
rohana mallawa
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Detach the control panel. Check for a small hole with a reset button which can be only pushed with a carbon pen tip once to reset the unit. When the car is running keep this pressed for about 5 seconds. The unit will reset. Refer to the below web address manual page 3 for details & a diagram. https://www.manualslib.com/manual/449215/Jvc-Kd-R330.html?page=3#manual
Posted on Jan 27, 2018
3 Related Answers
mike0862
Mikey
  • 6669 Answers
SOURCE: I have the jvc kd-r330 aand it has a battery
What do you mean by a battery source? Have you tested that there is a live feed to the radio? Have you checked the fuses in the fuse box? Have you checked the fuse at the back of the radio?
Posted on Oct 21, 2014
Keith Poitier
  • 106 Answers
SOURCE: Which car wire would you hook to JVC KD-R330 memory wire?
Constant power. In other words it should be hot even when the ignition is off. Most likely black. Put a voltage tester on the wire and to the ground point. If you read 12V with the ignition off, that's it.
Posted on Jun 09, 2015
jhnolson
  • 822 Answers
SOURCE: JVC CD RECEIVER MODEL NO. KD R330 manual
Manual Attached http://resources.jvc.com/Resources/00/01/52/GET0760-001A.pdf
Posted on Dec 02, 2015
I need a maunal for cd player Jvc Model KD-R330:
Try the jvckenwood website. Or a quick foogle search should turn up numerous places to get it from
Dec 31, 2016 | JVC Car Audio & Video
Jun 09, 2015 | JVC Car Audio & Video
I have the jvc kd-r330 aand it has a battery source. Gets power through the battery source but it won't turn on, or light up. Any suggestions?
Oct 21, 2014 | Car Audio & Video
I have the jvc kd-r330 and I have it hooked it. It has a battered source and power coming in but won't turn on or display anything.
make sure you have the ground wire is connected. If there is no ground radiop wont turn on, also make sure with a volt meter that there is power going to radio
JVC KD-R330 Won't turn off Demo mode - tried instructions. Every time I follow the instructions (Turn on, Hold Menu, push "vol" button, change to Demo off...etc) It doesn't work. In fact, as soon as I...
Do you have a Bluetooth adapter plugged into the KD-R330?
A compatible Bluetooth adapter (like the KS-BTA100) usually plugs into the rear auxiliary port of the receiver. It then needs to be "paired" with your Bluetooth device, for example, a Bluetooth phone headset.
What you're describing sounds like what can when no Bluetooth device has been "paired" yet.
If you don't HAVE a Bluetooth adapter connected to your KD-R330....is it possible you accidentally plugged something into its rear auxiliary jack? Or the front auxiliary? In other words, is it possible your KD-R330 receiver is mistaking some other device for a Bluetooth adapter?
Don't know if that helps at all...if there's no adapter issue, and nothing connected to the AUX jacks, probably your next step should be a call to JVC, or whatever number you were given for tech support.
On the bright side, since the receiver turns on, and responds to some commands, you probably didn't mess up anything major in the wiring. And, there's also the possibility the receiver is defective....certainly if this continues, and JVC can't help you, trying a replacement might be worth a try.
BTW, feel free to post a reply...I'm going to look further to see if there's any other documented issue besides an adapter that might cause the problem you're having.
Oct 29, 2013 | JVC Car Audio & Video
Directions for,setting up system
Go online on google, Type in the brand end model number of the deck in the search box, You will find sites where you can print off a owners manaul for no charge.
Oct 19, 2012 | JVC Kd-r330 kdr330 In-dash Cd/mp3 Car...
Jvhow to turn off demo on jvc kd330
Step 1 - Press and hold the source button
Step 2 - Press and hold the menu button
Step 3 - Press the round button
Step 4 - Turn knob until display says Demo Off
Step 5 - Press reound button
Step 6 - Press menu and you are done.
Jun 19, 2012 | JVC KD-R330 CD/MP3/WMA Receiver w/ Dual...
Car Audio & Video Logo
1,971 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
