Changed blower motor capacitor.
SOURCE: RUUD Heater and Ac MODEL #UGPH-07EAUER
It sounds like the thermostat is not functioning correctly. Has it been changed recently? I think the green wire is connected directly with red somewhere, maybe touching within the wiring in the wall. Also make sure the thermostat is set to auto not on. Sorry if you knew that but you would be surprised how many people don't.
Yes you should try replacing the run capacitor.
SOURCE: Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
SOURCE: blower wont run
make sure getting 220 v ac on imputs the relay my be bad hook up fan man to power check to see if getting a call from stat to make fan run green to common 24v ac hope this helps
SOURCE: The outside fan motor (OFM) will not turn off.
You probley have both power wires hooked to the bottem or power side of the contactor switch, one should be pluged into the bottem of the contactor, and one to the top, so when the switch opens, it breaks contact between the two wires (turns motor off).
