Dometic Duo-Therm - 13,500 B.T.U. Model #3107541.009 - Serial # WA346967 - Yr. 1999-2000. Blower motor will not start. Replaced the start capacitor - no help. It will run by spinning the motor by hand
Dometic Duo-Therm - 13,500 B.T.U. Model #3107541.009 - Serial # WA346967 - Yr. 1999-2000. Blower motor will not start. Replaced the start capacitor - no help. It will run by spinning the motor by hand and flipping the fan switch while it is still spinning. Compressor runs okay. I suspect it is the circut board in the control box. Or could it be the other start capacitor located next to the fan motor capacitor? If it is the controller circut board, where can I find a replacement (part number 3107168.001)
Posted by louiethek on
Anonymous
  • 400 Answers
Yes you should try replacing the run capacitor.
Posted on May 08, 2009
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
Have a 2006 cougar travel trailer with a 13,500 btu dometic duo therm (dometic part # 59516.531) I am currently living in the trailer and using ac all the time..About two months after i bought it ( ju
To check capacitor, take it off and male a assembly with a 100W lamp in series with the capacittor, if the lamp turns on good, it means you have good chances that the capacitor is faily good condition
Or use this test circuit. Don´t forget security procedures!!
Nov 15, 2014 | Heating & Cooling
Have a Duo Therm 59516.531 15000 BTU blower motor does not run checked cap 5mf ok tried direct power still nothing any thought. thanks
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
Jul 01, 2010 | Dometic 57915531 Air Conditioner
Heating & Cooling Logo
3,774 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
