The compressor was a little loud for sometime- today it stopped coming on- I hear click, it hums for a few seconds but the compressor does not come on...
The clicking sound you hear is the overload relay trying to start the compressor. The humming sound is the compressor. Purchase a overload relay kit. Unplug the unit. Remove the bottom back cover. On the side of the compressor is a black box. Usually held on by hard wire clips. Remove the cover. Inspect for burned wires. Take note of the relay components. Remove them and lay them out in the order and orientation in which they were removed. If you see burn marks on the you have a bad relay, also the white 'V' shaped component - shake it. If it rattles it is bad. Replace with the new overload. If everything looks good. With a multi-meter measure the Ohms across the three pins on the compressor. You will get One high reading. Across the other two you will get lower readings. The two lower readings when added together must equal the high reading. If they do not you have a bad compressor. To replace a compressor is a major repair. The cost is usually $600.00-$750.00.
Rule of thumb; "If the repair cost is 1/3 or more of your initial purchase price of the unit - Buy a new unit".
SOURCE: whirl pool side by side refrigerator problem
It looks like the Capacitor Start Relay is failing. It is located either on the starter Relay or mounted on the side of the compressor compartment. It sould have two wires on it, one orange and the other probably white.
SOURCE: Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
SOURCE: refridge hums then you hear
it sounds like
a bad:
SOURCE: Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
SOURCE: Bad capacitor/relay or compressor?
that is most likely a relay. Does the unit get cold while running?
Testimonial: "Thank you for your quick reply. Keeping fingers crossed it's only the relay."
