Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
A
Anonymous Posted on Oct 20, 2014
Check printer code=055
Info. code=055 check printer. How do I clear this code?
HP Color LaserJet Enterprise MFP M578. Error code 13.b2.ff.
Question edited for clarity 'make model error'.
Generic Paper Jam code for a jam in the fuser.
Video
Clear Paper Jam 13.B9, 13.B2, 13.FF Fuser - YouTube
https://www.youtube.com > watch
PREVIEW
1:05 No audio. Learn how to clear paper jams in the 13.B9, 13.B2, 13.FF fuser for HP Color LaserJet M65x, E650xx, E651xx and MFP M68x, E675xx, ...
YouTube · HP Support · May 19, 2020
HP LaserJet Enterprise M4555 MFP Printers - 13.B2.FF Error
https://support.hp.com > ca-en > document
Issue: A 13.B2.FF paper jam error appears on the control panel when paper is jammed in the top of the printer. ... Check the printer for jammed paper and clear ...
Missing: m578 ‎' Must include: m578
PREVIEW
HP LaserJet Enterprise MFP M577 - 13.B2.FF - PrintCopy .info
https://printcopy.info > code=13.B2.FF
1helpful
I have a KEVIN RM-133E remote however i lost the code of our KONKA tv can anyone help me ?
Jamir, KONKA CODES - TV 445 053 043 143 076, 103, 055, 004, 127, 016, , 044, 125, 120, 214, 215, 229, 235, 249
1034 1004, 1005, 1006, 1014, 1015, 1016, 1103, 1137, 1151
0707 0632, 0628, 0703, 1940, 0638, 1939 0037 0218 0418 0282 0587
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Remote Control Codes List TV SAT DVR
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
Remote control codes for Konka TV
4 Digit Universal Remote Codes For TV Codes For Universal Remotes
I have a Faema X2 Grand Italia C/10 NF and looking for descriptions of error codes (specifically #055). Is there a manual that gives such information?
ERROR 055 IS KTY PLUGS TO THE GROUP IN MY MANUAL,I'M A TECH AND THIS IS WHAT THE DESCRIPTION SAYS IN THE X2 TECH MANUAL... under possible causes it says either KTY disconnected or Malfunctioning card..solution is to open the machine CHECK CABLING/REPLACE KTY/REPLACE THE CARD.. hope this helps!!
2answers
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
2answers
Problems with the c760 900 service rip software error, can you help?
Perhaps this article on 900 Errors on a Lexmark C752, C760, or C762 will help. Just click on this link: http://bit.ly/c2xr1t. There are embedded links on the page for additional info. If you need further assistance, don't hesitate to contact Lexmark technical support or your authorized service provider.
Ibm 4232 printer 055 machine check msg ?????
While this is not for your specific printer, it is the same error code, and sounds like the printer is from the same series, so it may be of some use if figuring out this problem.
http://www.fixyourownprinter.com/forums/inkjet/25542
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Customer has a IBM 4230 printer with a machine check 055..
You are getting a carriage error indication (055). This can be a few things. First, you will have to make sure that your carriage rail is cleaned and there are no obstructions to the print head. Then I would recommend changing out the carriage assembly felts. There are two and they are located on the right and left side of the carriage assembly. Two little yellow or black if dirty O ring felts. You will also have to check your print head gap. You want to make sure that it moves from right to left freely when the printer is off and unplugged. If not you might need to perform an afta adjustment. If all is good then you are looking at a bad main logic bd. and it will need to be replaced.
If you have any question on how to do any of the above, I can supply you with free technical support as long as parts that are requested are ordered from us.
I carry all parts necessary to fix your printer. We also offer in house repairs if the job seems too much. Please contact me back if you have any question.
Thanks
Rory Cardenas
Account Executive
Midrange Repair & Parts
708-597-4222 x: 240
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
