Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panafax UF-885 - Error Code 055
Fax machine Panafax UF-885 -Error Code 055 -what is this code and how do I fix it?
  • 134 Answers
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Posted on Mar 25, 2009
Been receiving blank pages on random incoming faxes. Multiple error codes, but the one I can't find in the manual is code 212. This error code keeps reoccuring along with others.
Press the following keys:
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for the machine to reboot.
Jan 08, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
Info Code 060 on our Panafax UF 885
Code 060 means that the toner door is open. Check the switches.
You might have to tape the door closed on the rear side or call a technician to replace the door.
Nov 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
I have a panafax uf755e showing error code 054 and it won't print the fax's
054 is a laser unit error. Switch off/on..to clear. Otherwise it's an engineer job and unlikely to be cost effective.
Apr 12, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic uf885 error
Same here. I replaced the fuing unit but he error code 021 still is present.
Apr 01, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
415 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
