If you try to burn this on a single layer DVD disk then you will get this error message unless your DVD burn program can compress the video so it can fit on a single layer DVD disc. OTHERWISE You need to upgrade your burner to a dual layer burner and burn your video onto a dual layer DVD disc.
Well all DVD+R mean that when you finish copying files to the disk, the disk will lock itself and not allow any more files to be burned onto that DVD. The reason why you can'f fit your movie onto the disk is because the movie file may be bigger than the amount the DVD disk can hold. Just because the time of the movie is less than what the DVD can hold, doesn't mean its going to fit. Take for example a Blue ray movie, it may only be 120 minutes long but the file of the movie can be over 2 GB of space.
There is only one program at the moment that can decrypt Blu Ray movies. That is AnyDVD HD. You can download the free trial from www.slysoft.com but it is only good for 21 days, after which you'd have to buy it.
To burn the movie to another disk you would need a Blu Ray burner and blank blu ray media. Many Blu ray movies are very large, I think they average over 30 gb, so they won't fit onto the 25gb blank BD-R or BD-RE disks without compression or trimming out unwanted extras. 50gb blank disks are available, but are still very expensive. Of course, if the movie happens to be one of those small enough to fit a 25gb blank disk, then you can do a straight transfer.
You can use ImgBurn in UDF 2.5 mode to burn blu ray movies.
If you want to select just the main movie and one audio track, you might be able to fit a movie onto a BD-R 25gb disk, but it depends on which movie you are trying to back up. You can use tsMuxer to select portions once the movie is decrypted, and then output as a blu ray disk.
You can also use a program called BD Rebuilder. It will compress the movie to fit onto a 25gb blank disk. It can also compress to fit onto dual layer or single layer blank dvds....but those disks won't play in all Blu Ray players and the latest version's output is causing playback problems in PS3's when using blank dvds instead of blank BD-R disks.
You should also be aware that compressing high definition video takes a powerful computer and a great deal of time. My last attempt to compress a Blu Ray movie to a dual layer dvd size took 14 hours using a Core2Duo based machine
Are you burning the files with a DVD+R format. Use DVD-R. Not all players will recognize DVD+R. Also, check the region that the movies are made in and see if the player can be switched to that region. Also, are you trying to burn files larger than 700 MB. If you are, in creating an iso image or copy if you are downloading the file you have to match the checksum of the original file to the downloaded one.
If your computer recognizes a disc in the drive and operates normally, Id assume you would need a DVD player or codec to be able to actually watch the DVD. PowerDVD rings a bell.
Have you tired that? I know Windows Media Player by default wont let you watch a movie without first downloading a codec.
yes there is, there is plenty of software that will actually make any size move fit on a regular 4.7gb dvd, my definate favorite is CloneDvd2, also nero will, hope this helps and anything else i can help you with i am happy to help, also the most likely reason your dvd wont play the dual layer disc is that it doesn't support dual layer.
You should only have to finalize the disc and then it will work in your PC, you need DVD playback software to play it. If its a dual layer disc your, DVD drive in your pc needs to be able to play dual layer. Enjoy, Lee
Open it with NERO softwer and add some files to burn, down at the right end of window (nero's) have a line that says how much space on disc there is. Simple as this, I just caimed from my DVD dealer and he explained to me, Empty disc will always say 0 Bytes but if you open Nero Burner you'll be able to se how much of space is free on scale, after and whille adding files to burn image. Hope you understand me :)
