Memorex Products - Memorex - Dual-Layer DVD+R Discs, 8.5GB, 15/Pack - Sold As 1 - Record files ... (MemorexProducts05715) 8x Media Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does memorex dual layer dvd+r mean? How do you record a movie that is over 130 min. We purchased 240 min just for this reason and we can not get it to record over 120. How do you finish recording the movie? we paid extra more money for the Memorex Dual Layer for this purpose.. Thanks!
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on May 12, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
Helped
8789
Points
196
Well all DVD+R mean that when you finish copying files to the disk, the disk will lock itself and not allow any more files to be burned onto that DVD. The reason why you can'f fit your movie onto the disk is because the movie file may be bigger than the amount the DVD disk can hold. Just because the time of the movie is less than what the DVD can hold, doesn't mean its going to fit. Take for example a Blue ray movie, it may only be 120 minutes long but the file of the movie can be over 2 GB of space.
1helpful
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
2helpful
2answers
I have a multi-format dvd recorder double/dual layer from memorex, how do I burn vhs video to dvd video ?
you will need to save the vhs video file into a file before you burn it to a dvd also
http://download.cnet.com/Any-Video-Converter/3000-2194_4-10661456.html
Any Video Converter is an all-in-one video converting freeware with easy-to-use graphical interface, fast converting speed, and excellent video quality. It can convert almost all video formats including DivX, XviD, MOV, RM, RMVB, MPEG, VOB, DVD, WMV, and AVI to MPEG-4 movie format for PSP or other portable video device, MP4 player, or smartphones. It is the freeware to convert video files between multiple formats and download YouTube videos
hope this helps
1helpful
The DVD Burner will not burn a Memorex DVD - R . Should I purchase Verbatum or Memorex for an older model MSI DVD Burner? Or, Should I purchase Verbatum or Memorex for an older model Samsung TS H652...
You are on the right track. Every "multi-format" DVD recorder, DVD burner and DVD-RW drive I have ever owned has had problems with one type of media or another. This is because the discs all have their own patented dye mixtures, and each is a little bit different.
I have problems using Memorex DVD-R discs on my Toshiba DVD recorder. The only drive I can get good results with Memorex DVD-R's is on my Memorex DVD drive.
For DVD-R media, I have had the best success with TDK DVD-R's.So far, they have worked on all my devices.
You may want to try DVD+R media. I use Memorex Lightscribe DVD+R and for dual layer recording, I use Ativa DVD+R DL discs, both of which have worked very well and I rarely have to throw one away.
It takes allot longer, but on my PC I always use the "verify" function to make sure I get a good copy.
1helpful
Can i get a driver downloaded for my memorex external recorder part number 3202 3288 ?
You can get the driver here:
http://www.driverfiles.net/Other/Memorex/page,level2,135,3,resultpage1.html
9helpful
2answers
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Sai.
What kind of dvds do i use for my memorex dual format dvd recorde
Look at front of it. It should say RW DVD + R DL or -R DL. That means you can use DVD+R discs or DVD-R disks 4.7 Gb (depends which logo you have). If its RW DVD RAM DL it can be any +R or -R. In addition you can use DVD+/- R DL (dual layer) disks with 8.5 Gb capasity. But the cost is at least 2 -3 times higher than regular DVD.
Good Luck
DVD BURNING
yes there is, there is plenty of software that will actually make any size move fit on a regular 4.7gb dvd, my definate favorite is CloneDvd2, also nero will, hope this helps and anything else i can help you with i am happy to help, also the most likely reason your dvd wont play the dual layer disc is that it doesn't support dual layer.
I recorded a DVD on dual layer DVD
the size of the movie in terms of gb?
may be after writing first layer of the dvd, while going to 2nd layer problem starts
Player freezes on Dual-Layer DVD+R's... any ideas?
Its probably compabitilities issues. Try -rs. There a lot better since they are more known type and technology. the difference is +r have more editing features but in your case it doesn't matter because your just copying.
Top Memorex Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
