Question about Fagor Refrigerators
Switch off fridge for 4-5 hours, use hair drier and wire coat hanger
Posted on Oct 05, 2014
SOURCE: water is collecting in bottom
Hi, Refrigerator not Cooling or Fridge not Cooling Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Feb 25, 2011
SOURCE: Water collecting above drain hole,
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 23, 2011
SOURCE: How do i unblock the drain hole of my Miele kfn12823sd fridge freezer
Water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up like If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain lines. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Posted on Jun 11, 2013
Mar 13, 2015 | Refrigerators
May 11, 2014 | Fisher and Paykel Active Smart E522B...
Apr 23, 2011 | Whirlpool Refrigerators
Jul 28, 2010 | Refrigerators
Jan 28, 2010 | Maytag Refrigerators
Sep 29, 2008 | Refrigerators
Jul 27, 2008 | Bosch Refrigerators
May 04, 2008 | Refrigerators
Apr 30, 2007 | Kenmore 63462 Top Freezer Refrigerator
235 people viewed this question
