Question about Fagor 3FCA-68NFX Stainless Steel Refrigerator
Fagor refrigerator (3FCA-68NFX): no cold air in the refrigerator
I have a Fagor refrigerator (3FCA-68NFX) that has stopped working. To be precise, the freezer is working but there's no cold air in the refrigerator. The fan in the back of the freezer is working, it just seems there's no airflow to the refrigerator, the ventilation grills are unobstructed, but no cold air is coming out.
Posted by sdpurton on
Anonymous
    Champion:
  • 207 Answers
U may have a duct that goes from the freezer to the fridge that is closed off or u may have a stopped up freon line and if thats the case ur probably going to have to call a tech but check the duct first if u have one in that particular fridge
Posted on Mar 01, 2010
I have a fagor refrigerator that freezes everything. any advice
Make sure your filters are clean also nothing blocking air flow check and clean front vent
Sep 21, 2017 | Fagor Refrigerators
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Why does my Frigidaire Fridge always make a high pitched noise? I think it's about 10 years old maybe 5.... Does it need freon or service?
Motors make noise. You have 4. The evaporator motor in the freezer compartment, the condenser fan motor on the bottom back of the machine, a timer motor located in the fresh food compartment, next to the thermostat, and lastly the compressor itself, located in the bottom rear of the machine. You'll have to determine which area the noise is coming from.
However, I have seen many Frigidaire machines where the problem is in the compressor itself.
If you feel that is the problem, you can call a qualified Frigidaire service tech to verify that. If that's it, your looking at a very pricey repair. Lets hope it's one of the others.
Oct 30, 2009 | Fagor 3FCA-68NFX Stainless Steel ...
Fridge making annoying high pitch noise almost constantly
mine had a recall on the chipboard. fixed the high pitched buzz, but now i can hear the motor running stronger.
Oct 07, 2009 | Fagor 3FCA-68NFX Stainless Steel ...
The refrigerator is not keeping tempurature. Freezer is working fine
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Oct 03, 2008 | Amana Refrigerators
Fagor 3FCA-68NFX Stainless Steel  Refrigerator Logo
886 people viewed this question
Top Fagor Refrigerators Experts
Marvin
Marvin
Arnie Burke
Arnie Burke
Tom Chichester
Are you a Fagor Refrigerator Expert? Answer questions, earn points and help others
