SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
SOURCE: My blood pressure monitor is
Contact the HoMedic's Consumer Relations Dept @ 800-466-3342 Mon - Fri, 8:30am - 5:00pm ET, they can help you.
Keep in mind, that improper placement of the wrist cuff can cause higher or lower readings, than what they truly are. Also, not keeping your arm at heart level can cause an inaccurate reading.
SOURCE: I need to know that
Generally, the recalibration has to be done by the manufacturer, as the calibration has to be certified. Most manufacturers charge little or nothing for this service. Contact the number in your Owner's Manual concerning how they want you to send it to them.
Hope this helped and thanks for choosing FixYa.
