Filter pump was on auto and started @ the correct time but was still going after scheduled shutoff time and this alerted me that something was wrong. I suspect the pump kept running because the heater had tripped on.
SOURCE: I need to run the filter pump without power to the heater
dont worry about the heater it will not come on so turn the pump on before it turn green call a pool guy
SOURCE: When the filter pump comes on, the cleaner booster
check the programs or better cancel all the programs and restar from the begining if still after this the spa side switch need to be replace
SOURCE: Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
SOURCE: Hi-E2 350 heater trips thermal switch on exhaust
Check the condition of the heat exchanger. If it is heavily sooted from prior to adjusting gas pressure it will not vent properly. Check for downdrafting or blockage in the flue pipe if the heat exchanger is not sooted.
If the heat exchanger is sooted a good steam cleaning or even a trip to a car wash should remove enough soot for it to return to operating normally.
