I have pressed menu but nothing happens. I want to remove the blocks on the channels.
SOURCE: Our TV Sylvania blocks some progrfams on ch. 51
Go to the TV setup menu and look for the V-Chip settings. Turn it off altogether or if you have children you may want to just raise the block up to MA, R, or X rated programs
SOURCE: Cannot remove menu on sTV screen and TV will not turn off.
look for a recall button on the remote
this is normally the button that will turn on the on screen graphics
if the remote is not working point the sensor through a mobile phone with camera switched on and see if it flashes at you then you will know if remote is working
post back if you need any more help
From
the main menu choose "Parental Controls;" it's option six.
Choose
the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK
button on the remote, scroll through until the TV-MA rating appears. Press the
right arrow button to move the highlight over to the "Status" field
and toggle to "View." Press the OK button. This will set the
age-based ratings to Mature.
From
the Parental Controls menu, select the second option, V-Chip Movie Ratings
Limit and change the rating to TV_MA and the "Status" to
"View."
From
the Parental Controls menu select the third option, V-Chip Unrated Program
Block and select item one, which will be "View."
Select
the fourth option, which is "Channel Block." Highlight the Channel
field and using the channel up and down buttons, go through and check they are
all set to 'View." Any set to "Block" will need to be toggled
back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
