20 Most Recent
Sylvania SDVD7027BL Portable DVD Player Questions & Answers
My sylvania portable DVD player won't read
I had same problem with a sylvania portable DVD: no disc.
After cleaning the laser didn't work, I took the unit apart, and found that there is a small gear that moves the laser back and forth across the disc.. The gear could easily be misaligned with a rough bump along the drive.. All I did was realign the gear to the center where the disc was. Inside, there was even a small lever to pull back on to do this..
I also noticed a small Ribbon cable connecting the laser to the main board. Again, seemed nimble. I detached the ribbon, cleaned the connectors with alcohol and reattached.
Happy to say, it works perfectly now. :). Good luck.
12/22/2013 8:27:01 PM •
Sylvania...
Answered
on Dec 22, 2013
I have a Sylvania 55inch LED 4K TV Model SL551ANU that has sound but no image.
If your Sylvania 55-inch LED 4K TV has sound but no image, it could be due to several reasons. Here are some steps you can take to troubleshoot the issue:
- Check the connections: Make sure that all the cables connecting your TV to other devices, such as cable boxes or gaming consoles, are properly plugged in and secured. If any cables are loose, reattach them and try turning on the TV again.
- Check the input source: Make sure that the TV is set to the correct input source. If you're not sure, cycle through the different input sources using the remote control to see if the image appears on any of them.
- Adjust the brightness: Sometimes, the brightness of the TV can be too low, making it appear as if there is no image. Use the remote control to adjust the brightness of the TV and see if the image appears.
- Perform a power cycle: Turn off the TV and unplug it from the power source. Wait for about 30 seconds, then plug it back in and turn it on again. This will reset the TV and may fix the issue.
- Contact the manufacturer: If none of these steps work, it may be a hardware issue. Contact the manufacturer or a qualified technician to diagnose and fix the issue.
It's important to note that attempting to fix the TV yourself may void the warranty or cause further damage.
2/21/2023 3:30:34 PM •
Sylvania...
Answered
on Feb 21, 2023
SYLVANIA TV does not power on
- Check the power outlet: First, try plugging the TV into a different power outlet to make sure that the issue is not with the outlet itself.
- Check the power cord: Make sure that the power cord is securely plugged into both the TV and the power outlet. Check to see if the cord is damaged or frayed in any way, which could prevent the TV from receiving power.
- Test the power inverter: You can test the power inverter using a multimeter to determine if it is functioning properly. If it is not working, you may need to replace it.
- Check the TV's internal components: If the power inverter is functioning properly, there may be an issue with one of the TV's internal components, such as the power supply board or the main board. In this case, you may need to have the TV repaired by a professional technician.
2/15/2023 3:00:23 AM •
Sylvania...
Answered
on Feb 15, 2023
My Old Sylvania TV Is Stuck In Stuck With No Remote
If you do not have a remote for your Sylvania TV, you can try using the buttons on the TV itself to navigate through the settings and change it back to the video screen. Look for a button on the TV labeled "Menu," "Settings," or something similar, and use the arrow buttons to navigate through the options. You may need to consult the TV's manual for specific instructions on how to navigate the settings without a remote. If you don't have the manual, you can try to find it online on the Sylvania website or by searching for it on the web with the TV's model number.
1/25/2023 12:41:02 AM •
Sylvania...
Answered
on Jan 25, 2023
Can I use a universal remote app for sylvania LC320SL1
Hi.
It depends on the remote. If the remote app has the codes for your Sylvania tv, then you can use the remote. Check the list of codes that comes with the remote app and if it includes Sylvania codes, then there is a high possibility that the app will work with the tv.
Thank you.
11/26/2022 4:16:02 AM •
Sylvania...
Answered
on Nov 26, 2022
Replacement tv base/stand
Please check ebay and amazon for the replacement base/stand. If not available, you can reach out to your local Target or Bestbuy to see if they have anything in their catalogs.
Thank you.
11/5/2022 1:33:58 AM •
Sylvania...
Answered
on Nov 05, 2022
