Kenmore 24" Manual Clean Wall Oven 3052 Logo
A
Anonymous Posted on Aug 12, 2014
Kenmore wall oven 3052
Does not lite no gas flow it has gas on at the inlet.. but burner does not lite?
Lakeland Appliance Service
Level 2:
Champion:
  • Kenmore Expert 323 Answers
  • Posted on Feb 02, 2015
Kenmore Expert
Level 2:
Champion:
Answers
323
Questions
Helped
135457
Points
432
Most likely the igniter is not working at 100% and the gas valve won't open unless it is at 100%. Replace the igniter first.
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Nov 11, 2007
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Anonymous
  • 142 Answers
  • Posted on Apr 06, 2008
SOURCE: Oven burner pulsates
The gas regulator valve would also be my first guess. It seems to not be allowing enough gas into the system. When the top is on, only a small amount of fuel is required, and when properly mixed with the air all is well, but when you also put on the oven, the regulator won't allow enough gas into the system, so it's "burning lean". I'd get it fixed before it pulsates so bad that it actually blows out the flames and you're left with a propane smelling dangerous house.
Anonymous
  • 117 Answers
  • Posted on Feb 25, 2009
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Anonymous
  • 3361 Answers
  • Posted on Oct 05, 2009
SOURCE: My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Anonymous
  • 3600 Answers
  • Posted on Nov 13, 2009
SOURCE: My Kenmore gas stove has a light constant smell of
There is a problem with the regulator or the thermal bulb you need to call a repairman in to replace it, if you have a gas smell it is allowing the piolet light to have gas comming out and not lighting this is DANGROUS do not put it off get it looked at right away. This can kill you.
The wall behind my propane oven is black, why?
possibly the air shutters were not adjusted when new for propane use,most units come set-up to burl natural gas but need conversion to burn l.p. gas by changing the orfices on the top burners,then turning the orfice spuds down on the bake and broil orfices as to control the flow of a heavier gas and also opening the air shutters on these venturi gas feed tubes next to these orfices
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
1helpful
Kenmore gas oven does not reach operating temperature
If your oven is 20 years old the temperature sensor system might no longer be accurate, if you have access to a temperature measuring device that can confirm that the oven is not reaching 350 then run it up and check that its not just your indicator light system. Some oven burners have air control and yours may have accumulated oven soil over the years. If your burner. Is behind a short wall like mine is, use a mirror and torch to check. A clean can bring things back to standard. Flame heat is from a good mix of. Gas and Air...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
We have a kenmore wall oven and we need to know how to relight it. it is g a gas oven.
your oven lest its very,very old dose not have a standing pilot.it lites by demand when you turn on
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 • Ovens
How do i light my burner
GE jgrs14bew5bb gas wall oven temp button will not go higher than 360 degrees???
1helpful
2answers
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
3helpful
2answers
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
