How much would it cost ? how many days will it take ?
SOURCE: Pioneer cdx P1280 error11
pnoman: Your code means an electrical/mechanical failure. Follow this: 1. If the cartridge is stucked try to force it out slowly with a fine screwdriver. 2. Once is out or if already out without forcing it, remove all remaining CD's. 3. Insert a laser lens CD cleaner. 4. Clean it at least 3 times. 5. The unit must be disconnected from the 12V signal to be reset it at least 5 minutes, then reconnect. 6. If problem re-appears repeat procedure once more. If problems still, your laser lens is damaged and need replacement. Probably from $40.00 to $55.00. SithPitt
SOURCE: pioneer cdx p1280 cd changer,the cd magazine will
cd changer reqs a verygood 12v source,check for a good earth&check how many volts are going to changer with a good quality voltmeter,check at changer,not head unit
SOURCE: Pioneer CDX-P1280 12-Disc CD Changer not working,
pioneer CDX-1280 is very good cd changer. I highly recommend.
most problem of cd changer, when the grease dried up / soidefied it will stock up..
Solution:
just apply little grease (lubricant) to all moving mechanical parts.
[email protected]
