when ever i cut on my mp3 player the lights would flash on and off i have put a new battery in it and the computer will not respond when i put it in the computer
Fault at its main digital board. Lose of backlight control voltage from it to the back-light inverter board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
Take out the battery.
Reinsert the battery.
Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
Switch off the device.
Press and hold Volume Up + Home Button + Power Key.
After 2-3 seconds, release the Power Key.
You will enter boot screen, Select Wipe Data / Factory Reset.
Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Usually on an android device access settings : sd card and storage : select erase all or restore or factory reset and device will be factory restored . If the OS is completely gone you may have to access an image from te Coby website and install from a laptop by cable .
the factory reset is listed in the mp3 player menu's, if not there may be a little pin hole on the side, inset a pen tip and it should factory restore.
