When I watch TV, the entire way through the show the show hesitates and jumps and the picture will pixilate. Is this the TV or my internet connection?
Sound likes it is your internet connection.
try playing a DVD or Blu ray if it plays fine, it is def. your connection
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
go to the menu and see if the set is set to high power, if so change to low power , it may make a difference ...rob
SOURCE: Jumping Screen
I've had a couple of these. The panel control board is going bad, but there may be a way to make it last a bit longer. If you go into the MENU of the TV, and turn off all the color correction, all the whistles and bells that come inside the tv to "make the picture better," it usually helps. Any kind of motion correction, or any kind of noise reduction (picture noise reduction) should be turned off. If the picture has a cloud of green pixels that seems to pepper the screen, then after you turn off all the stuff in the menu, unplug the TV for 5 minutes, and then plug back in. It should help the picture some.
Hope this helps...
SOURCE: The TV picture stared jumping. Then lines were
If, indeed this is a polaroid clone TV, most probably the fix is a new "control board", at the cost of $400 if TV is not under warranty.
Sorry to not be of more assistance.
SOURCE: samsung plasma tv 42inch PS42E THDX Blue sparkles on dark areas
Hi yes i had the same problem and its basically because the tv needs a software upgrade. I contacted argos and they sent an engineer to sort it and he plugged something into the back of the tv to upgrade it. all in all it took 5 mins to do and not had a problem since.
SOURCE: LG TV - TV Guide Function Stuck
I have the same issue on an LG TV. The TV Guide is completely black with a small picture in the corner. It's as if the software is no longer working.
