Question about LG Televison & Video
LG Plasma inch has black pixalation around moving pictures only.
My LG Plasma 55inch has black pixals around moving pictures only. Picture is fine for DVDs and when pausing or non HD
Posted by wwa35768 on
SD Tech
    Top Expert:
  • LG Master
  • 14,553 Answers
It is likely NOT the set and if using a box for hd it could be it.
Most likely is signal is slow and set cannot keep up with it.
Posted on Mar 17, 2012
5 Related Answers
Anonymous
  • 92 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Posted on Oct 31, 2007
Anonymous
  • 15 Answers
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
Anonymous
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
Anonymous
  • 12 Answers
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Posted on Jul 07, 2009
David Low
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
My LG HD TV keeps jumping and hesitating and the picture pixalates is it my internet connection or is the tv going out
sound likes it is your internet connection.
try playing a DVD or Blu ray if it plays fine, it is def. your connection
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jul 22, 2014 | LG Televison & Video
Ps3 80 gig pixalated on hd screen beond reading.
That is usually a problem with the motherboard graphics chip. You would need a motherboard gpu reflow. To check this, connect a non dhmi cable to see if the same problem occurs,
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Camera has pixal bleed when reviewing pictures taken sometimes and will not take picture in automatic mode.
Did the camera get hot, this may cause LCD to bleed. Check menu settings and make sure the camera is not set to "Manual Focus".
Nov 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Green bar on left side and green pixalation
The Main bd has possibly failed along with P-Logic bd. Have a trained Samsung tech troubleshoot the set.
Jul 17, 2009 | Samsung HP-S4253 Television
I dont have continuous reception (picture is fragmented pixals)
Digital TV will do that when antenna does not receive sufficient signal.  You may need a different antenna or have to aim your current antenna differently. Go to www.dtvanswers.com for more info.
Jun 03, 2009 | Insignia 720p Widescreen LCD HDTV
My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Mar 07, 2009 | LG 42PC3D 42 in. Plasma Television
Screen is dark and pixalated
If u have warranty means then claim it.................
Jul 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Screen get pixalated and goes black
HI 99% OF CUSTOMERS THAT HAVE BROUGHT THE 360 IN TO MY SHOP WITH THIS PROBLEM ARE USUALY CURED BY FITTING NEW LASER
May 25, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
