Question about Philips 42PF9431D/37 TV
We have a Plilips 32 pfl. We have been playing DVD's with this TV but we cannot watch it with the entire width of the screen. When we watch our HDTV cable, it views the entire screen but not the (non-HD) DVDs. Is it possible to watch Non-HDTV with the entire screen?
Posted by smaxwell458 on
Anonymous
    New Friend:
  • 26 Answers
Of course its possible! You can use either your tv remote or your cable remote. On the cable remote it is usually the # sign, hd zoom, or stretch.
If you use your tv remote go into your menu and look for your setup or settings. Go to the picture option and select pass through or auto adjust.
You should be good to go after that:)
Posted on Nov 21, 2010
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
I have a philips tv model number 32 pfl 3805h/12 and was wondering if i can watch movies from an external hard drive? what format does the hard drive need to be?
Your TV does not have a USB port so you cannot connect an external HDD and stream movies on to the TV. But you can buy a HDD based media player which has the necessary output sockets as well as all kinds of decoders built in to stream movies on to your TV.
Apr 26, 2011 | Philips 32PFL5603D 32 in. HDTV LCD TV
Have alot of buzzing noise when we play a DVD but not when watching tv.
Verify the AUDIO cables from the DVD player to the TV they could be defective (even if new)
push the PLUGES firmly so they are correctly seated, play with (shake/move) the AUDIO cables while playing a DVD to see if it's not a loose connection
Cheers!
Jan 14, 2011 | Vizio L32 32 in. LCD HDTV
Can i connect a coby 5.1 dvd home theater system to a 32 inch vizio and be able to watch tv with the surround sound on. I know the surround sound can play while im watchin a dvd but i would rather just...
you need a logitech sound adapter or game adapter that costs 4-10$ on ebay.
Connect LR channels using an RCA cable and hook up the speakers on the other end of the game adapter
Jan 10, 2010 | Vizio VW32L 32 in. LCD HDTV
LG plasma tv burn in
sorry, thats the problem with plasma's, if it hasn;t cleared up you will have to replace the entire screen.
Oct 25, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
I have a 32" HD widescreen LCD TV/DVD combo. TDA03211c. When I put a dvd in to play it makes a noise and puts some digital garbage on the screen. Will not play dvds.
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
Oct 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Philips 42PF9431D/37 TV Logo
230 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
