Machine will not start ,no error code ,no delay start ,all lights working , water supply on
SOURCE: Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
SOURCE: error e51 on zanussi iz12
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
SOURCE: i have a zanussi 1200 6kg washing machine.
Hi, the flashing red light is an indication that you have a problem with your machine not spinning and draining.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
