Took drum out, belt not broken, idler seems ok. When unit turned on before and would not spin, made humming noise like motor was trying to work, I was able to move drum slow, but it would not engage and take off. Once apart, I powered up and fan comes on fine and spins motor. Possible the belt is just warn?
SOURCE: Replaced belt & pulley, now drum won't spin properly
Belt mounted upside down. Slick side goes to tub on this odd ball machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: power on but it won't spin.
You have a broken drive belt. To access the belt you have to remove the back metal cover.
The no heat problem could be a heating element or safety thermostat. These are also located under the back metal cover.
SOURCE: MGD3000AWW wont start
You have a malfunctioning control sector. i recommend replacing this damaged control board asap, if possible. it has failed.
SOURCE: Maytag Atlantis dryer drum not
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
