When turned on goes no video, black, power led is blue and dimmed. After 2-3 minutes disconnect power cable, connect it back on, push on/off button, is ok. please advice. thank you.
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
SOURCE: Viewsonic n4060w does not turn on
Welcome to our world... http://www.fixya.com/support/t285490-viewsonic_n4060w
This thing needs to go to a state attorney general if Viewsonic isn't even will to provide parts for these pathetic LCD TVs.
SOURCE: Viewsonic N3250W no power light ?
check out this website, it's got everything you need. I have to give all the credit to Alain, a brilliant guy in France who dug in and solved the problems. he gives instructions for the professional to fix the problem, but he also gives the sources for the power supply board to be purchased and for the little chip that causes most of the problems. I decided to take a risk and save some money and bought just the chip for $20 and very carefully soldered it in after removing the old one. The tv is fine a month later. The board comes out with no soldering, just some quick connectors and the back of the tv will come apart after you remove all the screws and the base by gently prying the back case from the front bezel along the sides of the tv. if you look closely, you will see the small cavities to pry from.
here's the website:
http://pagesperso-orange.fr/alain.mionnet/enii3210j.htm
SOURCE: Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
SOURCE: Viewsonic N3000w LCD TV randomly shuts off...
hi,guys with shutting down viewsonic t.vs.
As you power up your t.v continously press input button on your tv
until it powers on.Sometimes last all evening,someyimes for 5 minutes.
your welcome
