20 Most Recent
Swann Communications OutdoorCam Security Camera Questions & Answers
Daytime fine nitetime very little visability
It sounds like there is a light in the field of view of your camera. If so, the camera is adjusting to the brightest source of light it sees in the picture and the result is that everything else in the picture is washing out. Try repositioning the camera so that the light is behind the camera. If that is not possible or relocating the camera is impractical, then aim the camera so that the light is not directly within the field of view of the camera. This should improve the picture quality. Also, you don't mention the name or model of the camera manufacturer. There are cameras that are designed for and are more suitable for nightime vision. This may be an option if you are not able to get the desired result from your current camera. Hope this helps.
4/30/2010 12:52:25 PM •
Swann...
Answered
on Apr 30, 2010
Why does my Swann have no display?
If you checked all cable connections and made sure you monitor is set to the right input and working properly, if the dvr has multiple outputs try them all first. If none of that works it maybe the the video card on your unit is bad and may need replaced. Swann dvrs typically only last a couple years because the are garbage.
9/24/2022 1:04:50 AM •
Swann...
Answered
on Sep 24, 2022
Three cameras don't work anymore why?
try swappig the power supplys around from one that u know does still work , also ck your wires , if any run outside even for a little bit insects and animals can nibble I\on wires(they love the taste of em) and ruin cables
then I\using a spare camera go to each location and swap that around have helper to look for picture
3/18/2016 1:21:23 AM •
Swann...
Answered
on Mar 18, 2016
