How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Screen turns blue, if I disconnect I get "No Signal" message on blue screen; reconnect cable and "No Signal" message goes away.
Pressing the Up and Rewind buttons for 5 seconds the power LED on Fire TV box turns yellow and starts pulsing.
Screen turns black,then there is a message If you can read this to Select, I hit Select but Fire TV seems to continue going thru its process as I get alternate blue screens with black, I briefly get a screen that shows the viewing options (TV shows, movies,etc) but Fire TV continues on with alternate blue and black screens.
Finally LED on Fire TV turns solid white and tv has blue screen.
HELP!!!!
I have repeated this process several times hoping I would hit the right combination but Nope!
Pair your remote - after you insert batteries. For more info Go to set-up Your Network ConnectionsPair your remote - after you insert batteries. For more info Go to set-up Your Network Connections
Nope. Remote works fine. You folks aren't reading the entire question and comment.Nope. Remote works fine. You folks aren't reading the entire question and comment.
You can't post conmments that contain an email address.
Re: How do I get Amazon Fire TV resolution set so I get...
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Testimonial: "Have tried that. I get the logo then I get the blue screen."
To disconnect your Fire Stick remote from your TV, you can follow these steps:
1. On the home screen of your Fire Stick, go to "Settings" in the top menu bar. 2. Navigate to "Controllers & Bluetooth Devices" and select "Amazon Fire TV Remotes." 3. Select the remote you want to disconnect and then choose "Remove." 4. Follow the on-screen prompts to complete the removal process.
To reconnect your Fire Stick remote to your TV, you can follow these steps:
1. Turn on your TV and make sure that it is set to the correct input for the Fire Stick. 2. Press and hold the home button on your Fire Stick remote for at least five seconds. 3. Wait for the remote to pair with your Fire Stick. Once the pairing is complete, you should see a message on the TV screen confirming the connection.
If you want to disconnect and reconnect your Fire Stick to your Element TV, you can follow these steps:
1. Unplug the Fire Stick from your TV's HDMI port and power source. 2. Wait for a few seconds and then plug the Fire Stick back into the HDMI port and power source. 3. Turn on your TV and switch to the correct input for the Fire Stick. 4. Follow the on-screen prompts to complete the setup process.
Once the setup is complete, you should be able to use your Fire Stick and remote as normal.
If you are getting the Amazon fire stick error code 5505 up on your television screen then the cause is an error in your device location settings. You can fix it by correcting the location settings. We are providing the complete guide related to this issue so that you can read and fix it by yourself.
Guide: https://www.tollfreesupportnumbers.com/how-to/fix-error-code-5505-on-amazon-fire-stick
If part of your display is missing or cut off at the edges of your screen, your TV may be automatically scaling your picture.
You can use the Calibrate Display tool (Settings > Display & Sounds > Display > Calibrate Display) to adjust for this.
When you open the tool, you'll see four grey arrows pointing to the edges of your screen, which you can use as a guide when making your adjustments. Press the Up and Down keys on your Fire TV remote until the grey arrows are completely visible and touching the edges of your screen. Contacting Your TV Manufacturer .Follow the on-screen instructions to make adjustments with your TV remote. You should still see the grey arrows from the Calibrate Display tool--make sure the tips of the arrows are completely visible and touching the edges of your screen. Amazon Video Settings and Devices on the Amazon website.
Go to the Parental Controls section and enter a new 5-digit PIN under Amazon Video PIN. Then select Reset Your PIN. MicroSD Storage for Amazon Fire TV (2nd Generation) . USB Storage for Amazon Fire TV (1st Generation).If your storage device is compatible, try safely removing and then re-attaching it to your Amazon Fire TV:
Select Settings > Device from the Fire TV menu, and then select your storage device.
Select Eject.
Wait for the on-screen confirmation before safely removing the device.
Amazon.com, Inc.New Year New You. All .... Register or Deregister Your Amazon Fire TV Device ... If you purchased your Amazon Fire TV device from another retailer or received it as agift, follow the on-screen ... From the Home screen, select Settings > My Account. ...Differences between Amazon Fire TV and Fire TV Stick · Amazon Fire TV ...
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five ... If you received an Amazon Fire TV box or stick in your gift haul, .... Got an amazon fire tv stick and cannot access the home screen to register with my ...
Connect your Amazon Fire TV device to one of these network or router types:
Open, WEP, WPA-PSK, and WPA2-PSK encrypted networks
B, G, and N routers on 2.4Ghz
A and N routers on 5Ghz
Hidden networks
Enable wireless connectivity on your Amazon Fire TV device. From the Home screen, select Settings > System > Wi-Fi.
Make sure you know your network password (if required). If you see a lock icon, a network password is required. This password is not your Amazon account password.
Make sure your Internet connection is not down. Restart your router and modem to solve most Wi-Fi network issues.
Do not place your wireless router or Amazon Fire TV device in a cabinet, as it impacts your Wi-Fi signal strength.
Also, try this for Fire TV Stick:
Use the included HDMI extender to optimize the location of your Fire TV Stick. The HDMI extender can improve your wireless connectivity by positioning your Fire TV Stick further from the TV.
Plug the power cord into the included power adapter and then into a wall outlet to ensure the device receives enough power for optimal performance.
Still having trouble?
Restart your Amazon Fire TV device. Disconnect the power cord from your Amazon Fire TV device for three seconds, and then plug the power cord back in.
Tip: You can also restart your Amazon Fire TV device with your remote. Press and hold the Select button and the Play button at the same time until the Amazon Fire TV device restarts (about five seconds). Or go to Settings > System > Restart.
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
