20 Most Recent ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Questions & Answers
My n3260w tv has a backlight problem. When
You may have to decide whether it's cheaper to repair the old TV (if you can find a shop) or just buy a new one.
11/3/2017 1:19:16 AM • ViewSonic... • Answered on Nov 03, 2017
3answers
Remote control code (5 digit) for Viewsonic N3251w
This Works For My Viewsonic N4621W Code 10054
12/1/2013 5:33:11 PM • ViewSonic... • Answered on Dec 01, 2013
I need a working viewsonic code for my innovage remote.
Programming procedure is too much to type in here, and is not practical. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
11/10/2013 7:04:20 AM • ViewSonic... • Answered on Nov 10, 2013
3answers
My viewsonic n3260w
You need to find out if it is putting out the 24vdc needed by the backlight inverter board, you may have bad shorted out inverter board that may have taken out the fuse, you need to do some probing.
Power supply pin out: http://www.fspgroupusa.com/images/specs/FSP228-3F01_SPEC.pdf
Power supply: http://www.shopjimmy.com/fsp-fsp228-3f01-power-supply.htm
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
5/4/2013 11:31:08 AM • ViewSonic... • Answered on May 04, 2013
Viewsonic n3260w will not turn on no green light and I have check the plug ,cord and power at the wall
Good day!!!!That problem is usually cause of faulty capacitors on the power supply board..Just follow this instruction to fix your TV..1. Open the back cover of your TV.2. Look at the power supply board..Its normally connected to the power cord..3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..5. Some of the capacitors not bulged so its better if have a capacitance meter
7/11/2012 3:30:42 PM • ViewSonic... • Answered on Jul 11, 2012
S10-s3 remote
Try these codes.0046 0072
4/1/2012 6:52:35 AM • ViewSonic... • Answered on Apr 01, 2012
Tv will not start! It is
If the red light is blinking it is indicating an error or fault to the unit but the common fault of the lcd is the power supply. Try to remove the back cover of your tv then try to look for bulge up capacitor or leaky capacitor. The bulge up capacitor is that the top is not perfectly flat like the others and the leaky capacitor has a wet mark at the bottom of the capacitor. This faulty capacitor cause a unfiltered dc output and it cannot transfer dc output properly to distribute dc voltage to other parts of your tv. If you are not handy in electronics and not familiar with the electronic parts I suggest that you should contact a technician to do it for you and save you from stress. feel free to send feed back good day and best regards. Note before opening the back cover be sure to unplug the unit.
8/12/2011 10:39:22 AM • ViewSonic... • Answered on Aug 12, 2011
2answers
Replaced backlight inverter, tv came on for less
Check the fuse on the tv power supply board,replaced the fuse it is near the A/C socket for the A/C power cord to plug it into.Replacing fuse.If still have no power all,than the whole power supply board it is shorted out.The tv power supply board must have be replace to make the tv to work again.
8/10/2011 2:51:24 PM • ViewSonic... • Answered on Aug 10, 2011
I have a Viewsonic
The problem of your tv is in the power supply. In order to find the power supply of your tv ,you should follow the ac cord. But first you should unplug the unit and open the back cover of your tv there you will find the power supply, try to check the capacitors, it is cylindrical shape and has a plastic cover. Try to observed if their is a wet mark or oil mark that spread in to the pcb then replace it. But when replacing the capacitor you should observed the polarity of the capacitor and replace it exactly the way you pulled it out.
6/6/2011 12:13:28 PM • ViewSonic... • Answered on Jun 06, 2011
2answers
My Viewsonic n3260w has no
The tv T-CON board only board left could causes this problems.That the board usally sit at the middle at the botton of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
3/22/2011 6:15:42 AM • ViewSonic... • Answered on Mar 22, 2011
Power light flickers no other sign of power n3260w
If you get a flicker of power light then your problem is in your power supply, I would check for bulging capacitors and replace, if you don't find any then replace power supply, you can check places like shopjimmy.com, or discount-merchant.com or with an s, vancebaldwin.com
2/1/2011 11:25:23 PM • ViewSonic... • Answered on Feb 01, 2011
Need 3 or 4 digit tv code so that i can operate
try 760... if not, I don't know
12/5/2010 2:49:57 AM • ViewSonic... • Answered on Dec 05, 2010
2answers
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
10/16/2010 4:11:48 PM • ViewSonic... • Answered on Oct 16, 2010
I have a n3260w lcd.
You need to measure the DC output of the power supply to make sure it is putting out all the voltages first. It may be almost the same as N3250W.
Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
10/7/2010 10:07:58 PM • ViewSonic... • Answered on Oct 07, 2010
3235 viewsonic hdtv,comes on fine for about 2
Typical charge @ the repair shop can be from $150 and up + parts.
Your problem can be as simple as failing DC filter caps in the power supply, that will be the first place to look.
7/21/2010 8:19:01 PM • ViewSonic... • Answered on Jul 21, 2010
ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Logo
48 questions posted
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Televison & Video
Most Popular Question
lcd viewsonic tv no picture no sound
  • Televison & Video
