Evinrude Johnson OMC 0582508 - Ignition Coil Logo
A
Anonymous Posted on Jul 06, 2014
How to check a 175316 power pack? - Evinrude Johnson OMC 0582508 - Ignition Coil
phillipelecu
Level 2:
Champion:
  • Expert 254 Answers
  • Posted on Nov 06, 2014
phillipelecu
Expert
Level 2:
Champion:
Answers
254
Questions
0
Helped
71290
Points
313
Any spark at all?. The test gear is usually a dealer item.
My aceraspire4330 wont power on
you can try the power system check by doing the following:
To verify the symptom of the problem, power on the computer using each of the following power sources:
1. Remove the battery pack.
2. Connect the power adapter and check that power is supplied.
3. Disconnect the power adapter and install the charged battery pack; then check that power is supplied by
the battery pack.
If you suspect a power problem, see the appropriate power supply check in the following list:
"Check the Power Adapter"
"Check the Battery Pack"
Unplug the power adapter cable from the computer and measure the output voltage at the plug of the power
adapter cable. See the following figure
1. If the voltage is not correct, replace the power adapter.
2. If the voltage is within the range, do the following:
* Replace the System board.
* If the voltage is not correct, go to the next step.
NOTE: An audible noise from the power adapter does not always indicate a defect.
3. If the power-on indicator does not light up, check the power cord of the power adapter for correct
continuity and installation.
4. If the operational charge does not work, see "Check the Battery Pack"
Pin 1: +19 to +20.5V (Centre pin)
Pin 2: 0V, Ground (Shielding / Surround)
To check the battery pack, do the following:
From Software:
1. Check out the Power Management in control Panel
2. In Power Meter, confirm that if the parameters shown in the screen for Current Power Source and Total Battery Power Remaining are correct.
3. Repeat the steps 1 and 2, for both battery and adapter.
4. This helps you identify first the problem is on recharging or discharging.
From Hardware:
1. Power off the computer.
2. Remove the battery pack and measure the voltage between battery terminals 1(+) and 6(ground).
(Terminal 1 is closest to the edge, Terminal 6 is closest to centre)
3. If the voltage is still less than 7.5 Vdc after recharging, replace the battery.
To check the battery charge operation, use a discharged battery pack or a battery pack that has less than 50% of the total power remaining when installed in the computer. If the battery status indicator does not light up, remove the battery pack and let it return to room temperature.
Re-install the battery pack.
If the charge indicator still does not light up, replace the battery pack. If the charge indicator still does not light up, replace the DC/DC charger board.
I have the 300 watt xformer. Lights worked fine for quite a while...now the lights come on and go instantly off, agai and again almost 'flickering" I am positive I have less than 300 watts on the...
Use manual override and see if lights work correctly.
Check that bulbs are each working. If one bulb is burned out, then others will burn out, and the load change can cause power pack to stop functioning.
Always unplug power pack when working on lights.
Power packs do not have repair parts anywhere on the internet that I know.
I checked Intermatic, Malibulights, ebay, amazon, and listened to fixya customers.
Occasionally folks take power pack apart, but nobody reports being able to repair the transformer or timer.
Once power pack goes bad, then it needs to be replaced. Bad news because they're expensive.
'Harry' wrote to fixya with some information.
His timer stopped working so he bought cheap plug-in timer, set power pack to override, and then plugged power pack into cheap timer.
Harry also said his power pack has 5 year warranty and he was negotiating with Malibulights.com for replacement. No word how that came out.
Best I found are tips for next power pack that might save money:
The reason I add tips now, before your power pack needs replacement is some fella wrote fixya.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
How to troulbe shoot my 300-Watt Power Pack/Timer. it doesnt turn on but it does turn off on time. had this product for 4 years and just now started having problems with the timer.
'Harry' wrote to me yesterday with handy malibu information.
1) Power packs come with 5 year limited warranty.
He is contacting Malibulights.com for a refund of some type.
Hope he writes back and says how that comes out.
2) He was having problem and plugged power pack into wall timer, then set timer.
Heh heh, pretty clever: Malibu transformer works, but timer doesn't, so plug power pack into a wall timer!!
That being said, I had same problem with my power pack.
I used blower to remove dirt and sprayed wd-40 and tried to take it apart.
My power pack was getting electricity.
Connections were good where lights tie into wire.
My lights never turned off.
Power pack doesn't come apart.
I turned it upside down thinking water got into timer.
I took it inside and let it warm up.
It still wouldn't work so bought another one.
Then I searched Intermatic and Malibulights.com for answer, but they have no troubleshooting or repair other than check electricity and check bulbs.
Conclusion: when power pack doesn't work, it is broken.
Unless you buy a separate timer and plug power pack into that timer as Harry suggests.
After researching power packs at Intermatic, Malubulights.com, ebay etc, the best I found were tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
My malibu landscape 300w transformer does not want to come on
Check that power pack is getting electricity.
Power pack should make a small humming sound when on.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional voltage can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Is there a fuse (or similar) INSIDE a Malibu 600 TW (6.0 Amp)?
There is no fuse
There are no replacement parts for Malibu power packs
Malibulights.com has no troubleshooting steps
Here's what I learned:
Power packs are made to last many years 'in ordinary conditions' >> but they do give out.
Malibu power packs stop working and have to be replaced, they can't be fixed.
Power packs frequently stop working when people disconnect all the lights to work on the system, but they leave the power pack plugged in.
Power packs make a humming sound when ON.
Check electricity to unit to see if power pack has electricity.
Check your GFCIs in bathroom and kitchen.
Plug hair dryer into same receptacle to see if there is power.
Lights have to be replaced as soon as they burn out.
With burned out lights, the power pack will overpower and burn out other lights.
Evidently the power pack with no lights can also burn itself out.
When buying a new power pack, match bulb wattage with power pack wattage.
10 - 20 watt bulbs = 200Watt power pack.
15 - 20 watt bulbs = 300Watt power pack.
3helpful
My Malibu 200 Watt Power Pack/Transformer & Timer - ML200RT powers up but won't turn on lights. Is there a fuse that can be replaced in the unit?
There is no fuse and no repair parts
I've been all over the Malibulights.com website looking for anything that might help the large number of people with Malibu questions. The website has very little information and no parts and the site offers no help except the following:
1) Malibu gets the customer money, and other people troubleshoot for their customers
2) When buying a power pack, the total bulb wattage on the line has to match the power pack wattage
10 - 20 watt bulbs = 200 Watt power pack
15 -20 watt bulbs = 300 Watt power pack
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
If your power pack is oversized, it will burn out the bulbs and burn out the power pack
3) A power pack makes a humming noise when it has power >>> check your power source if power pack won't work >>> no other troubleshooting is offered
4) Replace burned out bulbs ASAP or the power pack burns out the other bulbs
5) Unplug power pack when working on bulbs [otherwise, the power pack burns out which is why people write fixya asking why their power pack won't work after replacing all their bulbs]
6) Nowhere on the Malibu site does it offer-or-explain burned out power packs or power packs that don't work, but they show plenty of new products for you to buy.
No spark runns fine then loses spark wait 10 minutes starts
The spark plugs receives power to spark from coil pack.Check the power at the coil pack and also check the voltage at the coil pack with meter.If the coil pack shows proper power as well as voltage then its fault in spark plugs.Otherwise its faulty coil pack.The coil pack receives power from battery.so also check the voltage of the battery it should be exact 12 volt.
If the battery shows low voltage then the battery needs to be re-charged.
Then check out.
Thanks. you can rate this solution and show your appreciation.
1helpful
I have an HP all in one C6180. I had a power
Check the power pack of the printer the surge must have damaged the power pack,check for blown fuse on the power pack that connects to the wall or replace the power pack with another one.hope this will help you
Top Evinrude Johnson OMC Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you an Evinrude Johnson OMC Boating Expert? Answer questions, earn points and help others
