20 Most Recent Intermatic Malibu 300W Power Pack Transformer ML300RTW Questions & Answers
I have a Malibu transformer 8100-0200-01, all the lights stay on no matter what the switch position is in, even off. I have unplugged the unit and waited trying to reset but problem still exists. Any
The digital transformer has 5 year warranty.Otherwise plug power pack into cheap wall timerhttp://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlDon't buy digital. This type timer can be easily knocked out with simple power outage.Also bulb outages and cord problems and moisture and probably direct sun can affect digital more easily than analog. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
4/12/2018 3:26:03 PM • Intermatic... • Answered on Apr 12, 2018
Where can I buy a replacement photocell for my Malibu 300W low voltage landscape lighting transformer?
You can buy the Malibu Photocell Low Voltage sensor on eBay. Go to eBay and search "Malibu Photocell Sensor" and you should see it. Or search eBay item number 371829265599
1/5/2017 3:37:39 AM • Intermatic... • Answered on Jan 05, 2017
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
6/16/2016 11:17:26 PM • Intermatic... • Answered on Jun 16, 2016
How do i replace timer mechanism in a malibu ml300rtw transformer with a photo cell
Following link shows photocell switch for ML300 series power pack http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 6:20:59 AM • Intermatic... • Answered on Jul 19, 2015
How to replace timer with a photo cell
They make a photocell for the ML300 http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 6:20:12 AM • Intermatic... • Answered on Jul 19, 2015
0answers
Resetting after too much power plugged in
Installation tips and troubleshoot steps on following link: Read installation tips and make sure your installation is correct now... http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install These low voltage power packs are actually transformers... larger version of the transformer you plug into wall to recharge cell phone... They are made for specific loads and can be damaged in variety of ways. Generally, there is no repair for damaged transformer.. Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/12/2015 8:07:47 PM • Intermatic... • Answered on Feb 12, 2015
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html I don't think they post schematic for the transformer But generally, the primary coil receives 120Volt AC input from household electrical outlet And the secondary coil produces 12Volt AC output for the low voltage lights. The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil. Output voltage on secondary coil is determined by the number of wraps and diameter of wire. Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights. Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 10:45:31 PM • Intermatic... • Answered on Aug 12, 2014
TDC DA-300-12w works but can't set any times or shut off
Timer not identified http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 10:34:42 PM • Intermatic... • Answered on Aug 12, 2014
I have a Malibu ml200rt power pack that is 3 years old and has worked fine. It is connected to 10 landscape lights each with a 12 volt 20 watt bulb. The lights stopped turning on. The timer is working
Intermatic power pack has 5 year warranty, while malibu has 1 year warranty: http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Open link above for installation tips and troubleshoot Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 9:57:26 PM • Intermatic... • Answered on Aug 12, 2014
Why doesn't the timer on my Malibu 300W transformer not keep the correct time? Actually, the dial didn't even move in the past 2 hours! What can I do?
Plug power pack into cheap wall timer, remove trippers from power pack dial, set power pack override to ON http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 9:55:22 PM • Intermatic... • Answered on Aug 12, 2014
How to set clock timer to over ride?
Rotate override knob located above dial. For permanent override, remove trippers from dial http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 9:37:11 PM • Intermatic... • Answered on Aug 12, 2014
600w transformer runs hot
Replace transformer.... it should be slightly warm but never hot http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 9:27:43 PM • Intermatic... • Answered on Aug 12, 2014
0answers
0answers
I have a 600w transformer and it have 2 300w
There are two sets of terminals on the 600 watt x-former. If you have two 300 watt circuits, use one 300 W circuit on one output, and the other 300 W circuit on the other output. Use terminals A & B on each side. Each circuit will have 12 volts. If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
5/19/2014 12:48:23 AM • Intermatic... • Answered on May 19, 2014
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
140 questions posted
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Mike
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Hardware & Accessories
Most Popular Question
replace timer photo cell
  • Hardware & Accessories
