20 Most Recent Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Questions & Answers
Troubleshoot:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If this is the digital type timer, the timer is defective.
But new one.
Read installation tips on link for longer lasting power pack
Install surge protector
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Malibu ML600TW -... | Answered on Jul 19, 2015
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Replace transformer.
Call about warranty
Gene
Malibu ML600TW -... | Answered on Oct 17, 2014
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
Malibu ML600TW -... | Answered on Aug 24, 2014
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.
Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etc
Reason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.
Add a comment and attach photo as needed.
Malibu ML600TW -... | Answered on May 26, 2013
Yes, use ML 600 with 5 year warranty.
Save receipt.
Copy following link for useful information about getting new power pack to last longer.
ML 600 will have 2 sets of ABC terminals.
Each terminal supports 300 watts.
Split lights between both sets of terminals.
Use 12 gauge wire. Maximum 75' length each wire.
Malibu ML600TW -... | Answered on Apr 16, 2013
1) Copy following link for malibu replacement trippers, troubleshoot overview, tips, and warranty information:
2) After reading information on link above, add a comment and describe which transformer you have, and if this is new installation, or older installation that worked before.
Malibu ML600TW -... | Answered on Feb 10, 2013
Jan 2013
1) Yes. With 6 amps.
It is not purely code, but generally not dangerous.
Most household outlets and switches sold at home center are actually rated 15 amp, and should be on a 15 amp breaker. just don't overload.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
2) However if you are running close-to or higher amps than 15 amps, such as space heater (volts x amps = watts), then I would suggest installing 20 amp arc-fault breaker, and protect whole circuit.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
3) Add comment and say what you do.
Malibu ML600TW -... | Answered on Jan 23, 2013
1) Copy following link for full resources on operation, wire length, bulb wattage, warranty, troubleshoot, etc
2) Add comment Dec 2012 for more qassistance
Malibu ML600TW -... | Answered on Dec 16, 2012
Copy following link for ML600 installation manual, installation tips, problem-avoidance, troubleshooting, replacement trippers, warranty information:
With the ML600, there are usually two sets ABC terminals.
Connect wires to AB terminals unless using photo eye.
Connect 300 watts to each set of AB terminals.
Malibu ML600TW -... | Answered on Nov 22, 2012
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
94 questions posted
Top Malibu Hardware & Accessories Experts
Gene Haynes
Tom Chichester
ray gallant
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Malibu Hardware & Accessories
Most Popular Question
ml500tw timer transformer don 39 t
  • Hardware & Accessories
